Results 1 to 3 of 3
Reload Thread: Plexi Window
    fenderplayer391's Avatar
    fenderplayer391 is offline Junior Member
    Mar 2004
    Chicago, IL
    Plexi Window
    I'm gonna get 2 Audiobahn AW1206T's and i'm gonna build a sealed box for them. If I put plexiglass back on the box, will this hurt the sound or will I just blow the back off since i'm gonna be hittin' 2000Watts??
    Also........where can I buy a sheet of plexi?
    ghs_wrestler189's Avatar
    ghs_wrestler189 is offline CarAudio.com Elite
    Jul 2003
    Greenwood, IN
    28
    1,493
    15
    Re: Plexi Window
    I've experienced it only in a good way, it made my 15's hit at more frequencies than in a regular sealed box. I recommend definitely giving it a try.
    AIM:ghs wrestler 171 - hit me up anytime.
    My Sounddomain Page
    1998 Oldsmobile Intrigue
    RE SX 15" D4 is here with a 5.0 cuft box tuned to 46 hz for comps.
    Port plug for 32hz daily.
    MTX 81000d give it 1225 rms at 2 ohms.
    143 on the new termlab (old box...5.1@36hz).
    Quote Originally Posted by jemorgan85
    ^I wish I were a woman .
    ryanc's Avatar
    ryanc is offline Junior Member
    Mar 2004
    Wisconsin
    14
    Re: Plexi Window
    I would recommend either doing a cutout window of 1/4" plexiglass (if you don't do the entire back as plexi), or do the whole back in at least 1/2" plexiglass. Home depot usually has 2' x 4' or 36" x 42" (i think) sheets of 1/4" for about $30. Other than that, www.usplastic.com has thicker stuff in full sheets and in cut sheets.
  1. framing out a window.....
    By azone in forum General Discussion
    Last Post: 03-26-2004, 12:16 AM
  2. Replies: 18
    Last Post: 11-06-2003, 07:25 PM
  3. Plexi amp window
    By PeaveyBassist in forum Enclosure Design & Construction Help
    Last Post: 10-21-2003, 09:06 PM
