+ Reply to Thread
Results 1 to 10 of 10
Reload Thread: 2 12"s or 3 12"s in only 7 cubic feet... could polyfill be the solution?
    RSDXzec's Avatar
    RSDXzec is offline Senior VIP Member
    Dec 2011
    Australia
    478
    1 Post(s)
    so i have 3 12"s and an amp that can take all 3, problem is i thought i'd have more room than i do. ideally i'd like 10cf, but i figured only 9cf would fit. After more considerations i'm left with 7cf external dimensions. I'm building this box for a hatchback and i'm really keen to have 3 12s in there but i'm not sure if it would work well. Would you guys recommend going for 3 12s or 2 12s in the same space, the box will have separate chambers for each sub and i'd be sending about 500wrms to them altogether either way.
    The chambers will be tuned to 30hz.
    My other thought was polyfill, if i put some of that in there would that theoretically increase the volume it sees? Hopefully i can get this closer to 9cf total.
    Cheers.
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    36
    6,275
    30
    20 Post(s)
    Re: 2 12"s or 3 12"s in only 7 cubic feet... could polyfill be the solution?
    what does the amp do power wise with two subs only.? we need way more information. amp specs., sub specs
    TaylorFade's Avatar
    TaylorFade is offline I fail.
    Dec 2009
    Baton Rouge, La.
    2,678
    132 Post(s)
    Since when is 7 cubes not enough for (most) (3) 12's?
    And why seperate chambers? When using a common, you can get away with a bit smaller box.
    Quote Originally Posted by eCrack View Post
    TaylorFail
    Quote Originally Posted by Suicide Bobb View Post
    Taylorfail, v.2
    Quote Originally Posted by Imtjnotu View Post
    tailorFail v.3
    Quote Originally Posted by brodeisel View Post
    TaylorFail v.4
    Quote Originally Posted by tat2bass View Post
    TaylorWin v.1?
  4. Thanks Falcons thanked for this post
  5. #4
    RSDXzec's Avatar
    Dec 2011
    Australia
    478
    1 Post(s)
    Quote Originally Posted by subzero View Post
    subs are (soundstream) a single PCW-12 and two EG-12X, they both have exactly the same T/S parameters.
    The amp is an audiopipe apsm-1500 which i should be getting in the mail next week so it's more than enough regardless of my setup choice, though i'll probably keep it at 500rms either way because my cars electrical isn't that great.
    Quote Originally Posted by TaylorFade View Post
    Well the subs are about 5 years old, and they were bought separately on ebay so they would've been treated differently, so i assumed it was a bad idea, am i correct in saying that?
    this sub is recommended between 1.25-3cf sealed, so i would've liked to go a little higher ported, i have been modeling them in winisd to get an idea of the response and keeping it under the excursion limits.
  6. #5
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    28
    6,652
    11 Post(s)
    So ur gonna run different model subs in the same install????? Sounds great...
    RIP Christopher Maynard Martin "My heart"
    HU - Eclipse CD7000 For Sale
    Front Stage - 4 Silver flute 6.5's & 4 Seas Prestige tweets 1 set of each left
    Front Stage amp - DB Drive A7 125.4 Sold
    Subwoofer - 3 Skar VVX 10's (Looking for 4th so I can run amp at .5ohm) Sold
    Subwoofer Amp - Skar SK-2500@.67ohm Sold
    Box - 4.25cf tuned to 30hz using a 6" internal aero 15" long.. Sold
    Wiring - Knukonceptz everything, Big 3, Sprinter S12V370F & HC1800 Sold
  7. #6
    RSDXzec's Avatar
    Dec 2011
    Australia
    478
    1 Post(s)
    Quote Originally Posted by disturbed471985 View Post
    they have exactly the same T/S parameters, i think you missed that part, look exactly the same, they're just rebranded, the only difference is the letters on the back.
    it's not like i'm running an L7 with a T6
    this is an EG-12X
    Soundstream EG-12X (eg12x) 12" Subwoofer - Sonic Electronix
    PCW-12
    Soundstream PCW-12 (pcw12) 12" High Performance Subwoofer
    all of mine are the single voice coil versions, i'd like you to find the difference between them then tell me what i'm doing is wrong.
    modelled the spl graph, and the cone excursion graph, red line is with 2 subs, and the excursion graph has been modelled as if they'd been in separate chambers, i also have the T/S specs in there. This is comparing 2 vs 3 in the 7cf enclosure tuned to 30hz.
  8. #7
    Jun 2009
    Greenwood, La
    28
    6,652
    11 Post(s)
    hmmm like u said just rebranded old stock.. SS always on top of the cutting edge arent they..
  9. #8
    subzero's Avatar
    Sep 2008
    Phoenix, AZ
    36
    6,275
    30
    20 Post(s)
    all three should work in a 2.5 cube sealed. 3 cube ported box.
  10. #9
    RSDXzec's Avatar
    Dec 2011
    Australia
    478
    1 Post(s)
    yeah no doubt they'd work in a much smaller box sealed, i'm just trying to get the most i can out of them ported. And when I look at the response curves i'm debating whether or not to have all 3 or just use 2.
  11. #10
    subzero's Avatar
    Sep 2008
    Phoenix, AZ
    36
    6,275
    30
    20 Post(s)
    Quote Originally Posted by RSDXzec View Post
    notice they dont have recomeded spec on ported. do like I suggested. I used to have a pair or those tens. your guess is as good as anyone else. your not too far off RMS power. build it at sealed specs and add a port. andif it is too high, add fill. every cube, add one pound get 1/2 cube stimulation. then your still getting a 4 cube box with low tunning. just manipulate things and figure it out.
+ Reply to Thread
  1. WTB: 12/15" Q or 12/13 W7 IN BOX and in cali!
    By twisted001200 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 08-10-2007, 02:44 PM
  2. 12" type r or 12" fubar
    By lukeduke28 in forum Subwoofers
    Last Post: 10-17-2006, 03:41 PM
  3. 12" type-r, 12 PG RSD, or 12 CV V-max?
    By espguitarist91 in forum Subwoofers
    Last Post: 07-05-2006, 08:47 PM
  4. WTb - 12" IDQ V2 or 12" ID V3 - Any ohm
    By marley1 in forum Wanting to Buy (WTB) - Car Audio
    Last Post: 05-25-2006, 07:17 PM
  5. Replies: 12
    Last Post: 05-03-2004, 05:59 PM
