Results 1 to 6 of 6
Reload Thread: Ramos! Let's Talk Bondo!
    Omarvelous's Avatar
    Omarvelous is offline CarAudio.com Elite
    Jan 2004
    Queens, NY
    33
    1,371
    Ok, u seem to know a lot about bondo.
    I bought some Bondo Body Filler, from Bondo the company.
    The instructions are.....sketchy to me.
    They say for every 3 in diameter circle, 1/2 in thick of filler i should use 3 in stip of hardener?
    Does this sound right?
    Reason i ask is, it's a lot of filler for such a small amount of hardner.
    And on a side note, just want to make sure.
    -Bondo the imperfections
    -Sand while hardening (Grit A)
    -Primer
    -Sand (Grit B)
    -Paint
    For Grit A and B, what do you recommend?
    Thanks a lot man U ROCK!
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: Ramos! Let's Talk Bondo!
    Nah, it's all the fiberglass and body filler fumes I have absorbed over the years that sank in
    It sounds about right to me . But I myself would do a little expiramenting with small amounts of each to get the mixture right for your current weather. If it's cold ( below 60 ) you might need to mix it a little hotter ( more mekp ) warmer a little less. Too hot though will make the bondo brittle when it dries.
    For A the roughest you can find. The absolute best thing to use is a cheese grater style body file. What your doing here is getting rid of all of the ridges and high spots in the filler.
    B will need to come before the primer.
    B I would step down progressivly from 120 to 400 or 500 grit.
    Anything else let me know
    5 % equipment
    90 % install
    5% beer
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    You may also want to apply a small skim coat after sanding if there are any pin holes. A few layers of primer and some blocking should take care of any imperfections or sand scratches after that.
    Personally, I would finish sanding my bondo after the 400 grit and then do 400 and then 600 blocking (possibly even wet depending on the finish you are looking for).
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Omarvelous's Avatar
    Jan 2004
    Queens, NY
    33
    1,371
    Thanks a lot guys.
    What did you use to mix and apply it?
    Was thinking wooden splint sticks.
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    Look around at a body supply shop. They have spreaders of different sizes that are used for that.
    2006 Jeep Liberty
    *Vb = vol. in cu"
    BDIDDY's Avatar
    BDIDDY is offline Sittin' Slick
    Mar 2003
    Tennessee
    30
    2,575
    Usually you would use a rubber spactula or spreader (?). But DEFINATElY sand while it's like hard play-doh. That way the ridges and everything are taken care of. If you have a big surface, hell even a small one, a D/A or Orbital sander does wonders. I sanded my bondo down with something like 30 grit or so. I can't remember what it was I just asked for the grittiest **** I could find.
    Hope this helps...
    "Just have to remember to take everything in stride, and don't put off till tomorrow what you can do today because there might not be a tomorrow. " <---- RAMOS
    Profliepower is the funniest guy ever...
  1. Anyone know how warm it has to be to use Bondo Resin?
    By Pete in forum Enclosure Design & Construction Help
    Last Post: 03-08-2004, 03:54 AM
  2. RAMOS, u seem like u know a good deal. Id like to see ur setup, got any Pics?
    By MXJMR in forum Car Audio Competition, Shows and Events
    Last Post: 08-09-2003, 11:53 PM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
