Results 1 to 1 of 1
Reload Thread: Semi-Complicated Box Design (I Think?)
    nosaj070's Avatar
    nosaj070 is offline CarAudio.com Veteran
    Feb 2003
    Chicago, IL
    27
    2,394
    I'm in the process of designing a slot ported box for my ED B3 12. I would like it tuned very low, 26-maybe 30 hz. Max Dimensions are small, height=14.5, width=22, it will also be a trapezoid, so top depth should be around 10-14 inches, and it will have a 70degree angle against the back of the seat.
    Sub Specs are here:
    Fs - 22 hz
    Qts - 0.35
    VAS - 4.25ft3
    spl - 88
    qms - 3
    qes - 0.4
    Xmax - 23.3 mm
    displacement 0.1 ft3
    Thanks,
    Jason
    P.S. Jmac, i'll help pay you're bills if you help me
    Alpine CDA-7995, A/D/S 3 Series Comps, ED 8A, SoundStream Reference 604, 98 Civic Sedan
    AIM: nosaj070
  1. bigger box = lower bass???
    By infinity1412 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2004, 01:01 PM
  2. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  3. check out my box design!!
    By runningame21 in forum Enclosure Design & Construction Help
    Last Post: 01-23-2004, 07:12 AM
  4. box design please help building tommorow
    By slipknot87420 in forum Enclosure Design & Construction Help
    Last Post: 01-06-2004, 08:18 PM
  5. Need a design for a ported box for a 12" XXX
    By BulldogSr04 in forum Enclosure Design & Construction Help
    Last Post: 10-22-2003, 10:21 PM
