Results 1 to 11 of 11
Reload Thread: 2 12" ported box
    knotdrummer88's Avatar
    knotdrummer88 is offline CarAudio.com Elite
    Jan 2012
    Toledo, OH
    737
    4 Post(s)
    2 12" ported box
    Im building a box for my buddy's either accord or civic, I can't remember. But anyway Im designing it now, and its for 2 12" aq sdc 2.5's. My questions is, well I'm looking at doing subs back with side port. With the side port, the port wall will be what the back of the subs backs up to, now if say one of the subs backs up to the port wall, but the the port ends before reaching the other sub, will that effect how it plays? sorry if it doesn't make much sense, Im not really sure how to word it, but any help is greatly appreciated, thank you!
    GAMEOVERCCA's Avatar
    GAMEOVERCCA is offline INCRIMINATOR AUDIO
    Jun 2011
    Hickory NC
    1,722
    9 Post(s)
    Re: 2 12" ported box
    Quote Originally Posted by knotdrummer88 View Post
    ......what
    Subs
    2 IA Death penalty 15's
    Highs and Mids
    2 IA Comp sets
    Amps
    1 AB VFL200.1
    1 Mmats SQ4150
    Batteries
    3 Deka intimidator 1000amp 100ah AGM's
  3. Likes MisterDeadeye liked this post
  4. #3
    Jan 2012
    Toledo, OH
    737
    4 Post(s)
    uh...Im not sure how i can differently explain it, like I haven't checked on the specs exactly yet, but say if the magnet was 2" from the port wall, and the other one would be 6" from the back wall, does the difference there make any difference in response of the woofers?
  5. #4
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,671
    17 Post(s)
    it will load the drivers differently. Most cases not enough to matter. I have one sub loading directly into the throat of my horn and it only moves .25'' more then the other.
    I am protesting Skar by giving them added exposure in my signature.
  6. #5
    Jan 2012
    Toledo, OH
    737
    4 Post(s)
    what if I made the box deeper so theres more room behind the subs that help eleviate that at all?
  7. #6
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    No noticeable problems.
    If the subs have a pole vent, then you need clearance or there will be problems.
    http://crunktimes.com/ct/
    nG - BSEE
  8. #7
    May 2007
    4,671
    17 Post(s)
    unless your box is 100% symmetrical your subs will load differently. But as I said the first time, there usually isn't enough difference to matter to the ear. I would worry more about room around the box.
  9. #8
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Are you doing a slot port or round ports? If there is a sub by the mouth of the port it could unload. Ideally you want the sub to be as far from the mouth of the port as possible and if there are multiple subs, you want them to be spaced an equal distance from the mouth of the port.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
  10. #9
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,337
    134 Post(s)
    Do a rear firing port. I've done too many civic and accords. Port rear has always sounded better.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    buck.box.designs@gmail.com back up and running!!!
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - Batcap - DC - eD - Excessive Amperage - Rainbow - Shuriken
    In Nashville? Pm me.
  11. #10
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    I agree with this as well.
    nG - BSEE
  12. #11
    Jan 2012
    Toledo, OH
    737
    4 Post(s)
    ok,subs back port back it is, ill try designing a new box, but will there be any problems with it being to big at approx 2.5 to 3 cubic feet?
  1. 12" XXX Ported Box tuned low...suggestions needed!
    By Gregory in forum Enclosure Design & Construction Help
    Last Post: 02-06-2005, 01:02 PM
  2. 12" XXX ported box design?
    By WHITEBLAZER in forum Enclosure Design & Construction Help
    Last Post: 06-02-2004, 08:44 AM
  3. Replies: 2
    Last Post: 01-28-2004, 12:24 AM
