Well - I finally decided to go (1) 18" Sub... [RE XXX18 or FI Q18]
... The vehicle is my 1999 Nissan Sentra GXE 4-Dr [B-15 Motor Swap] - 20" Rims BTW...
OK - I'm looking to do a Trunk Wall... Everything firing forward into the the cabin
... I'm wanting a Deep Low End Street Beat Setup!
... The Amp I'm going to be using is a Kicker KX2500.1D [Birthsheet says 3060rms @ 2ohm - But I'm going to be running it at a 4ohm load... I'm guessing 2200 - 2500rms maybe]
SOOO - This is what I came up with a 6.481Cuft Tuned to 29Hz...
... The dimensions are: 32"W x 18.75"H x 24"D - I'm going to be use (1) 6" PVC [9" Long]
... My question is:
Is the design[It's simple, i know] - Optimal for what I'm looking for?
* If someone could help - guide - point things out - etc... It'll all be GREATLY! appreciated... *
Register To Reply
Bookmarks
