Ok... Got the above subs. Want to port the enclosure rear-firing subs and ports (preferably), for an suv. They will be on a single amp, so I guess they need to share a single airspace and port. Suggestions? Never done the calculations on porting multiple subs so not sure how to even design it to specs, or where I should start. I have enough room to have them in-line but i'd probably need the port(s) to go on the top or bottom and i'm not sure if that's best for stability of the box. Materials will be MDF.
Register To Reply
Bookmarks
