Results 1 to 6 of 6
Reload Thread: 12" kicker comp vr enclosure
    jaegerbombs's Avatar
    jaegerbombs is offline Junior Member
    Jan 2012
    Meridian, ID
    15
    1 Post(s)
    Icon14 12" kicker comp vr enclosure
    So this is my personal debate between myself. idk if i should go ported or sealed? I have a pair of the 03 cvrs i am stuck with. Only pair i can use right now. im looking to get alot of low end truck shaking base. i am wondering if i should build a ported or sealed enclosure. i know sealed is better sound quality, blah blah... these are the measurements i was looking to use for a sealed angled box. 24"tall, 50" wide, 5" top' 10" bottom which gave me like a 3.78 cu/ft box. If a ported box is better, what demensions (in those balpark area) should i use. thanks for the advice ahead tme.
    DoesDad's Avatar
    DoesDad is offline CarAudio.com Veteran
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Re: 12" kicker comp vr enclosure
    CVR's love ported like all Kicker subs except the solo classic. And if you can get fit that big of a sealed box in your truck you can definitely go ported.
  3. Thanks jaegerbombs thanked for this post
  4. #3
    Jan 2012
    Meridian, ID
    15
    1 Post(s)
    yeahhh all i am basically loosing in my single cab f-150 is some leg room but ill live! will that same box demensions still work? and i was thinking a 4 in round PVC tube port? could i go from the top near the edge and go down? was thinking of tuning it to 33hz making the tube 14.35" long? should i do lower or higher hz?
  5. #4
    DoesDad's Avatar
    Dec 2011
    Tulsa, OK
    2,342
    675 Post(s)
    Wrong guy to ask for box specs. Lol! There's a bunch of guys that will help you out though. I know I usually like my stuff tuned lower. 32-35. I've had 2 CVR's. had em' on only 600 rms and they got pretty loud.
  6. #5
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    It will depend on what kind of room you have behind that seat. If you can get enough volume while still be ok to drive then you can do ported. If not..then you are stuck with sealed.
  7. #6
    Jan 2012
    Meridian, ID
    15
    1 Post(s)
    Well like I saaid with those specs, I get a 3.78 cube box. Planning on putting in a divider so they both have own airspace.
  1. Two 12 in. Kicker Comp VRs or one decent 15?
    By systembumping in forum Subwoofers
    Last Post: 05-12-2006, 04:44 PM
  2. slot-ported box plans needed for 12 inch kicker comp vr
    By Scarface in forum Enclosure Design & Construction Help
    Last Post: 01-30-2004, 02:00 PM
  3. kicker comp vr enclosure
    By loudmusiq in forum Enclosure Design & Construction Help
    Last Post: 05-13-2003, 05:59 PM
  4. power 2 kicker comp vr 12"
    By anthonyfg in forum Amplifiers
    Last Post: 04-07-2002, 03:04 PM
  5. Kicker Comp VR 12'S - bang for the buck?
    By Unregistered in forum Subwoofers
    Last Post: 03-19-2002, 11:59 AM
