I got a sealed box should be around 4.5 after bracing and everything is inside including the port if only using 1. My question is would you use 1 or 2 6" ports. If I go with 2 then they are going to have to be kinda external a little bit but that don't bother me. Also do you guys fire your sub to the rear of the car and port on the side or what? Sub is tc axis. Thanks
Register To Reply
Bookmarks
