Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Reload Thread: what box..
    BNolan12's Avatar
    BNolan12 is offline CarAudio.com Elite
    Mar 2010
    Lake Charles, LA
    640
    what box..
    What type of box would make the 2 JL 10" W3 that i have sound the best? Ported/sealed? What should i make or get made for these? Looking for SQ and they will be going in a Isuzu I-280(same make as chevy colorado) ext. cab. Let me know if ideas yall have.
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    any box builders on at the moment??
    murph's Avatar
    murph is offline Low for Life
    Sep 2011
    Richmond,VA
    3,480
    89 Post(s)
    Re: what box..
    w3's in a sealed box should sound nice no need really for someone to build you a sealed box though...
    Hu: kenwood kdc-x995
    Sub: Boston acoustics G5 12 in a quasi 6th order
    Amp: Eclipse Xa5000
    Front Speakers: Eclipse sc6500
    HIT UP FOR BASS ---> http://www.youtube.com/user/BassWithMurph?feature=mhee
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,094
    351 Post(s)
    Re: what box..
    Depending on the area you have to work with you can do them sealed or ported. Which ever works for the situation.
    You can pick up sealed enclosures fairly cheap, you just need to ensure they are the correct volume. Many times they say they are xxFT^3 but are really yyFT^3. Also you would need to seal up the enclosure if you were to purchase a prefab sealed enclosure. They are notorious for leaks.
    pimpala22's Avatar
    pimpala22 is online now borrocho
    Sep 2011
    wtx
    1,035
    4 Post(s)
    Re: what box..
    if you have room ported..but if not do a 1.25 each sealed
    2005 Chevy Impala
    In dash - Pioneer avh-p3200
    Front - Alpine spr-17s 6.5
    Rear - Alpine spr-69 6x9
    Amps - Hifonics bxi2610, jl audio 300/4
    Subs - 2 15" Incriminator Audio Death Row
    box- 8 cu ft net tuned to 32-33 hz
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    yeh i could handle building a sealed box, what size would you suggest? i built a box or 2 before but i never came up with the dimensions on my own but if i'm given them i can build it.
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    Quote Originally Posted by pro-rabbit View Post
    yeh i would seal it, how do i tell if it's xx^3 compared to yy^3???
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,094
    351 Post(s)
    Re: what box..
    Quote Originally Posted by BNolan12 View Post
    Math
  9. #9
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    Math
    figured that..whats the equation or what do i look for?
  10. #10
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,472
    81 Post(s)
    Re: what box..
    For a sealed box if you are given the outer dimensions of 14" x 14" x 9", you can calculate the net volume by subtracting 1.5" from each dimension (MDF is 3/4" and two sides equals 1.5"). So 12.5 x 12.5 x 7.5 = 1170. Divide that by 1728 (amount of square inches in a cubic foot) and you are left with 0.68 cubic feet. If the manufacturer is advertising 0.9 cubic feet then you know you are being misinformed.
  11. #11
    pimpala22's Avatar
    Sep 2011
    wtx
    1,035
    4 Post(s)
    Re: what box..
    LxWxH/1728=cu ft
    2005 Chevy Impala
  12. #12
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    Quote Originally Posted by Kangaroux View Post
    awesome thanks
  13. #13
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,094
    351 Post(s)
    Re: what box..
    This is exactly right.
    However, you also need to take into account your subs displacement to ensure you are at the correct volume.
  14. #14
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    ok so on JL's site, it says the ideal sealed box is a .625 cubic feet box (measurements given are 18in. x 11in. x 9in) do i just multiple everything by 2 in order to get a box to house both subs or how do i go about that?
  15. #15
    BNolan12's Avatar
    Mar 2010
    Lake Charles, LA
    640
    Re: what box..
    the driver displacement for a w3 is .049ft^3
