Results 1 to 14 of 14
Reload Thread: Advice for Ford F150 SCREW, 04'-08'. Ported or sealed, need a better solution.
    prevail's Avatar
    prevail is offline Banned
    Dec 2010
    Jackson WY
    175
    STILL looking. Have an 04' screw. Looking for a box that will not require a seat lift, looking for interior to stay stealth. All of the pre-fabs top out at 5 7/8" mounting depth, and all I can run with my current box is "low profile" subs. (currently two RF 12"s). They aren't cutting it for me right now, but i will be putting more power to them today or tomorrow, and see if that helps.
    I guess that I am also looking for a sub suggestion that will work. I am not opposed to sealed, as long as it has GREAT musicality, and decent SPL capability ( but don't need to do hair tricks!). Any suggestions? Anyone think I can get better performance out of my existing subs with a custom box?
    Have any of you seen designs that can possibly mount a sub on an angle or different axis in order to achieve greater mounting depth?
    Thanks, this has been a challenge to find the 'best' solution...
    Not opposed to 2-3 great 8"s or 1-2 10"s, mounting depth seems to be the only limiting factor, (as well as the PITA 60/40 bench seat 'feet' that break uo the box possibilities...)
    May 2009
    Arlington, Tn
    1,310
    Re: Advice for Ford F150 SCREW, 04'-08'. Ported or sealed, need a better solution.
    I had the same truck(07) and posted a pic last night of my setup in a different thread. We are extremely limited with what we can do under those seats. But, fortunately, there are subs out there can give us the response we want. I ran 2 DD1508s and loved them. I fed them 1000w each off an AQ2200 and kept them in my truck until I sold it. You cant go wrong with those or maybe a couple SA-8s. I dont think you would be able to feed them as much power as the DDs, but they will still sound **** good. Here's a link to my build to give you some ideas. I'm sure this isnt the ONLY way to do it, but it worked out fine for me.
    Build for 07 F150 SuperCrew
    All girls are whores, just ask your mom how you got here.
    Feedback Thread
    http://www.caraudio.com/forums/buyer-seller-feedback/407829-blackfx4intn-feedback-thread.html
    underdogg's Avatar
    underdogg is offline Member
    Nov 2011
    sc
    76
    I have two Memphis shallow flat sub for sale that will work great for ur setup ..
    prevail's Avatar
    Dec 2010
    Jackson WY
    175
    Seriously, If you don't have that truck anymore, but still have that box, I want it!!
    Nice work. Do you still have a cut sheet/plans, etc?
    I think this is exactly the direction that I am leaning towards.
    What is the max mounting depth you acheived with that?
    prevail's Avatar
    Dec 2010
    Jackson WY
    175
    I already have two brand new RF shallow 12"s, I don't think the Memphis ones would be enough of an upgrade to just try that in my existing pre-fab sealed box...
    May 2009
    Arlington, Tn
    1,310
    Yeah, I still have it and have been trying to sell it here only locally due to the freight costs. The box plans are on another computer that I no longer own. But I might have it in my email folder from where I sent it off to someone else who bought the plans. From the part of the baffle where the sub actually mounts, is 6 1/4" to the bottom. Ideally, I believe you want 1" clearance around the magnet in all directions twords any walls. But, .75" was fine for me. Those DD's had a mounting depth of 5.5".
    Feedback Thread
    prevail's Avatar
    Dec 2010
    Jackson WY
    175
    Hmmm. Lets work up a shipping quote to 83001, and see what happens, OK?
    May 2009
    Arlington, Tn
    1,310
    ok, I will go out and measure it, and guess on a weight.
    Feedback Thread
  9. #9
    May 2009
    Arlington, Tn
    1,310
    Wow, shipping wasn't as bad as I thought. Fed Ex 3 day $50.80 But, I totally guessed on the weight but I think it's about right at 55lbs.
    Feedback Thread
  10. #10
    prevail's Avatar
    Dec 2010
    Jackson WY
    175
    Can you PM me a bottom dollar price? I won't even charge you a disposal fee...;-}
  11. #11
    May 2009
    Arlington, Tn
    1,310
    PM'd
    Feedback Thread
  12. #12
    prevail's Avatar
    Dec 2010
    Jackson WY
    175
    Bump, now I need to figure out what the options are for subs for this great box. Heh. I said 'box'.
  13. #13
    Cali_Screw's Avatar
    Cali_Screw is offline CarAudio.com Elite
    Aug 2008
    Rancho,CA
    755
    What amp you plan on running? SLP or SQ goals?
  14. #14
    12listen4's Avatar
    12listen4 is offline Junior Member
    Feb 2012
    chattanooga tn
    by chance did you sell the enclosure? or did you find the plans?
    12listen4@gmail.com
