Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Reload Thread: 18 audioque hdc3 what hz box
    Casey Harmon's Avatar
    Casey Harmon is offline Junior Member
    Oct 2011
    New York
    i have a 18 AQ and im geting a box built what should i get it built to i was thinking 36hz what do u all think
    Kangaroux's Avatar
    Kangaroux is offline I put on
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Re: 18 audioque hdc3 what hz box
    What airspace? Are you going to be using it for a daily setup? How much power and what kind of music do you like listening to?
    Oct 2011
    New York
    i have a db 2000.1 amp and its a daily set up will go to one or two comps just to see what im hitting and im getting the box built so i have no numbers to give him so i was looking for ideas i just want to get the best out of the sub as i can
    Kangaroux's Avatar
    Dec 2010
    Maine
    9,487
    81 Post(s)
    Well the HDC3's definitely prefer a higher tuning if you want to get the most out of it. I think you should be fine with tuned to 36.
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,401
    138 Post(s)
    I like 34.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - AT - ASE (local) - Batcap - DC - eD - Excessive Amperage - Powermaster - Rainbow
    In Nashville? Me too! Pm me and come hangout!
    brodeisel's Avatar
    brodeisel is offline The Cool Newb
    Jun 2011
    iowa
    4,301
    38 Post(s)
    Buck you always like them tuned lower
    Bought from- pjc, boomsday, El Weenie, Sacsking, BassinBuick, Kangaroux
    Sold to- Mast240
    I DONT PROOF READ SO DONT TRY TO MAKE ME MAD BY BEING THE GRAMMAR POLICE. NOT A SINGLE F*** WILL BE GIVEN.
    Quote Originally Posted by keep_hope_alive View Post
    Spend a few decades answering questions. Women are stupid. You can win any arguement with a women if you don't let logic get in the way. Ignore logic when dealing with women. Focus on feelings.
    Moble Enclosurs's Avatar
    Moble Enclosurs is offline Box Designer/Builder Moble Enclosurs is a Supporting Member of the forum!
    Moble Enclosurs is a Supporting Vendor of the forum!
    Jul 2011
    New London, Connecticut
    1,398
    34
    80 Post(s)
    Proper compression says to go with 41.35Hz, so even 40 would be fine. Yes, they do require higher tuning as kangaroux mentioned.
    "You build for physics....you design for acoustics. Just because you can build a box, doesn't make you a designer....and vice versa."
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,078
    348 Post(s)
    From my hands on experience(if that counts for anything considering AQ/DD lol) tuning higher with them yield great SPL results and horrible musical performance. However, tuning 30-35 depending on application works amazing for them. The T/S listed on the site are way off and do not look for them to change them or give you more accurate ones as that won't happen.
  9. #9
    Buck's Avatar
    May 2008
    Nashville
    17,401
    138 Post(s)
    Quote Originally Posted by brodeisel View Post
    I know. IMO subs shouldn't play over 55-60 hz. I just think lower tuning sounds better. I have messed with quite a few AQ's in real life and that has been my favorite tuning. Yes they will play low even tuned high, but they don't sound good doing it.
  10. #10
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,671
    17 Post(s)
    no they do not require high tuning, they require it for break in that is all.
    They play flatter and sound better tuned lower to help compensate for their low xmax. I actually have experience with AQ and DD's plenty of it, I maybe ran 20 different boxes for my 12's.
    Small chamber, huge port, tune low, that is how dd's and aq's like it.
    They best box for them is an abc box how ever
  11. #11
    Buck's Avatar
    May 2008
    Nashville
    17,401
    138 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    Since when do HDC3's have low xmax?
  12. #12
    May 2007
    4,671
    17 Post(s)
    Quote Originally Posted by Buck View Post
    since forever?
  13. #13
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,456
    4 Post(s)
    I liked my 15 when I had it...box was tuned to 36hz
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
  14. #14
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,078
    348 Post(s)
    Depends on which version of the HDC he is talking about. In truth they were not designed for large excursion until this last version which were discussed/designed while I was there.(Not saying I had anything to do with that though...just pointing out that I was there during that time.)
  15. #15
    May 2007
    4,671
    17 Post(s)
    I'm talking the original hd3c's, I forgot they changed them again.
    the ones with the dd/soundstream baskets on them.
