Dd 9512
I have done some searching on box specs for this sub however I just want some opinions on box specs for the purpose of what I will be using it for.
To start the sub is a 9512 F motor, This will be for a daily driver and not for competitions or anything, I will be putting 2000-2500rms to it from a critical mass ula2500 at 1 ohm. I listen to both hip hop and rock music but mostly hip hop. I need the dimensions to be a little on the shorter side and not super wide but can go pretty deep as this will be in a trunk. I want it tuned in the high 30's like 37-39, maybe someone can give me their recommendation on the tuning. Also can someone tell me if I should go 2.5 cu ft or higher than that.
For what I will be using this sub for someone with more experience please give me full specs on a box that would work for me so I can take it to my box guy and have him make it for me. Thanks in advance.
Refs: Bought From: dacheatham, photocrazy8, Bob Saget
SQ build in the process
Bookmarks
