Results 1 to 2 of 2
Reload Thread: blowthru from trunk
    S4MICHIGAN's Avatar
    S4MICHIGAN is offline Junior Member
    Aug 2011
    MICHIGAN
    13
    blowthru from trunk
    Is it favorable to have a blowthru going thru the center arm rest? What would the pros and cons be? the car is a 2001 s4 would be a 15" something (still trying to figure out) which direction would the sub face? twords the seats or trunk?
    thanks
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    36
    6,304
    30
    20 Post(s)
    Re: blowthru from trunk
    Any will work. You should start by viewing the build logs. check mine out.
