Results 1 to 14 of 14
Reload Thread: Newbie help -- ported box
    Z3n's Avatar
    Z3n
    Z3n is offline Junior Member
    Aug 2011
    United States
    26
    Hey guys, I'm a complete newb when it comes to designing and building my own sub enclosure. In fact, the system I'm installing is my first system, so I'm a car audio newb too. :P
    I've read the Basic EDU for a ported sub box but I still need some help and some questions answered. :P
    The subs I'm working with are Kicker CompVR Aluminized. I'm going to be putting two in and have a ported box. Each sub needs 1.75 to 2.25 cubic feet, and I'm going to go with 2 cubic feet.
    So what I need help with is the port and tuning the subs. I want to tune the port tuned to 35 Hz. I'm using WinISD at the moment to figure out the dimensions for the ports but I need some help/input.
    So the specs that I have right now are these: 2 in x 12.50 in by 23.25 inches deep. Does that sound like it would work? I have the other things set at 2.00 cubic feet and 35 Hz tuning.
    Second, for the positioning of the port, should I have it so that the ports join up as one or should I have for each sub, like on the outer edge of the box on each side?
    Sorry if this is long winded and all. If there's any more info I need just say so and I'll try to find it!
    Thanks!
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Re: Newbie help -- ported box
    Ehhh just buy my box
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
    Z3n's Avatar
    Z3n
    Aug 2011
    United States
    26
    Hey I'd buy a box, but sadly I'm a high schooler with a limited budget. :P
    Anyways, I think it'll be a good thing to figure out how to do now so I can make better boxes if I upgrade my system later. Plus, my dad's a carpenter so I have all the tools I'll need, and he can help me.
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    O ya might as well... I just know I **** it them so I buy hahaha
    Western Rep.
    Z3n's Avatar
    Z3n
    Aug 2011
    United States
    26
    Well if I find out I'm absolutely lousy at designing/building my own box I'll probably have to resort to buying too. But this'll save me some money. Hopefully.
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    It should cuz of shipping unless you eff up like me and gotta keep buying sheets off wood hahaha
    Western Rep.
    >>SQL<<'s Avatar
    >>SQL<< is offline CarAudio.com Elite
    May 2011
    USA
    1,461
    1 Post(s)
    It is nice to see someone new here actually do research before posting.
    Here is what I recommend
    Have a box designed by an expert here who will basically provide you with a blue print you can follow.
    Ram-Designs, Mobile Enclosures are 2 of the guys on here that do designs.
    That way you get to learn while still building your own box.
    Z3n's Avatar
    Z3n
    Aug 2011
    United States
    26
    Hopefully we don't screw up too much wood. :P
    Okay, now I have another question. :P So what I'm thinking now is having the two subs share one port in the middle. If I have them sharing a port do I need to change the port size, like double it? Or should I just make a separate port for each sub and still have them in the middle, just divided?
  9. #9
    Z3n's Avatar
    Z3n
    Aug 2011
    United States
    26
    Crispin, how much would it cost to have one of those guys design a box for me?
    EDIT: Ignore that, checked Ram Design's website. I'll think about it but I'm still going to look into how to design my own box. :P I'm just cheap like that. But I will seriously consider Ram Design. He looks like he does good work.
  10. #10
    >>SQL<<'s Avatar
    May 2011
    USA
    1,461
    1 Post(s)
    Ram Designs is a pro
  11. #11
    Team TH (Donny)'s Avatar
    Team TH (Donny) is offline Team Truth Hertz
    Mar 2011
    Mattoon, IL
    926
    1 Post(s)
    Got measurements (Max area you have to work with; H/W/D)? I will help you out for free.. Just PM me.
    2000 Mustang GT "Spring Feature"
    • Substage: Under construction..
    REFs
    Sold To: vitveet, jager, traks, 1ndatrunk, Nut Hair Trick, Crapalier, Jakerrr, pjc, audiobaun Bought From: traks, xmakeafistx, Dman3047 Traded With: Nut Hair Trick, Wingsfreak9, theslamologist
  12. #12
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    4,706
    15
    85 Post(s)
    Have both subs share the same airspace and do one large port. I'd do the port on a side as opposed to between the subs. Just change the port size/number/etc. on winISD and it'll cough up the correct length and let you know if your port velocity is too high or not.
  13. #13
    schrummy's Avatar
    schrummy is offline CarAudio.com Elite
    Jun 2008
    Ames, Iowa
    1,381
    the port area is determined by the available air space that is inside the box. Most people will say use 12-16 in^2 of port area per cubic foot of internal airspace. so say you need 4 feet^3 of airspace, after displacement, and you decide to have 12 in^2 of port area per cubic foot. that would yield 48 in^2 of port. from there use WinISD to find out the length of port you would need......
    Team TREO
    Team Midwest
    Team Gorilla
    USACI- trunk 0-1000 156.4 and climbing
    153 sealed on the dash
    yes its a trunk car and yes its only (2) 12s...
    refs=sold to......R/T Pimp, mustangowner, zyklonb, Miles0803
    Bought from…..2002XLT, R/T Pimp, 92c1v1c, Miles0803, camshoc, dbeez, goindef154
  14. #14
    kushy_dreams's Avatar
    kushy_dreams is offline The resident hippie
    Sep 2009
    twenty past four
    4,108
    25 Post(s)
    Its easiest to just put the port to 1 side of the box when doing your first slot port. You could always use 2 4inch pvc pipes as well. I prefer to use round ports cuz you just cut the hole out and drop in the tube ans glue around it and you're done.
    13 Dodge Dart Rallye 1.4T
    DD 2515 Supercharged
    RF T1500bdcp
    Audiotechnix wire and deadening
    http://mobileaudioforum.com/forum/forum.php
    BOYCOTT SKAR AUDIO! SHADY BUSINESS PRACTICES SHOULD NEVER BE ENCOURAGED!
