Results 1 to 5 of 5
Reload Thread: is 33.5 sq. in. of port enough for 2 image dynamics ctx 10's?
    skylineTT's Avatar
    skylineTT is offline bass=sekz
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    Building a box for a 92 civic hatchback and am dealing with 35in wide, 20in deep, and 12in of height. I used the re calf and I can get 30hz tuning with a 1" port. I'll post a pic of my design. 2 10s sub up port back about 8in from the hatch and 5 below window line.
    Refs: Dipitydoo, appollyon, bad95gt, revrider1, jwh1598, ampjunkielikeme, deathpenalty18, ssackett, snoopysnooper, corey0928, SPLAudio, Clifff150, CL1CKCLACK, ShawnT, West + more
    Dirtrider4eva's Avatar
    Dirtrider4eva is online now √\_The CaUsE__
    Mar 2011
    Milwaukee, WI
    4,145
    16 Post(s)
    Re: is 33.5 sq. in. of port enough for 2 image dynamics ctx 10's?
    you want to keep about 12 inches of port to 14.4 sq inches of port to every square foot of internal volume.
    welcome to
    Where b-stock is the new a-stock
    TEAM WEST
    skylineTT's Avatar
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    hmm good rule of thumb.. ill post box design and make sure it follows that guideline
    edit: ahh at 3.22 cubes, it doesnt look like that is quite enough
    edit2: if using the 12 sq in guideline, im sort of close. these subs are going to be pushed at about 400w.
    skylineTT's Avatar
    Jun 2007
    Dallas/Raiderland
    4,003
    5 Post(s)
    sub specs.
    akheathen's Avatar
    akheathen is offline trianoacitol contraceptiv akheathen is a Supporting Member of the forum!
    Jan 2011
    Anchorage AK
    31
    2,196
    22 Post(s)
    i would also take the port to a width of 1.5"min. and install to stiffening runners of doubled mdf in the middle, essentially cutting the port in thirds. if the port area is still too great, you can always make the runners wider.
    *IF I have forgotten to exchange feedback, please let me know*
    i buy broken amps....
    No, i will not "gift" paypal. please do not even make it awkward by asking. if the fees are an issue, I am usually inclined to add them. unless you have discount elsewhere, shipping is through usps flat rate, through usps parcel post, or through the roof..... i am in alaska. thanks
    -Heath H-
