Results 1 to 8 of 8
Reload Thread: double baffle question
    usarmy1494's Avatar
    usarmy1494 is offline Junior Member
    Jul 2011
    Chicago, il
    27
    Why when there is a double baffle does the volume go down? is the calculator putting the 2nd baffle in the box?
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,436
    6 Post(s)
    Re: double baffle question
    put the double baffle on the outside of the box. meaning use the bottom of the double baffle as your measurement and add the double baffle on top of that.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
    mast240's Avatar
    mast240 is offline YOU'RE A HOOKER!
    Mar 2011
    washington, dc
    3,332
    5 Post(s)
    yea... if you use a double baffle with the same measurements... the volume will go down
    NEW TO CAR AUDIO? READ THIS FIRST... http://www.caraudio.com/forums/general-discussion/532425-new-car-audio-read-first.html
    the loudest montero sport around
    head unit: toshiba thrive 10.1" android tablet/ Kenwood KVT-516
    front stage: each door: 1 8' RF p1 (midbass), midrange: 2 cadence cwm6.5's, 1 memphis pr 6.5 coax (kickplate), 1 cadence 4' coax (a-pillars)
    subs: 4 AQ HDC3 18'S, walled in a clamshell
    amps: subs: AB 500.1, looking for a second; midrange and midbass: 2 AP 1000.4
    optimusprime's Avatar
    optimusprime is offline roll out.
    Jun 2011
    westbrook, ME
    451
    you seem baffled by the baffle.
    Quote Originally Posted by dubstepchick View Post
    wtf....you are just an *** hole
    Quote Originally Posted by Bohemian View Post
    I am taking it like a man.
    Quote Originally Posted by -01limited- View Post
    Nothing like seeing a stupid monkey dancing to dubstep.
    usarmy1494's Avatar
    Jul 2011
    Chicago, il
    27
    yes i am. ok so my box volume with out the 2nd baffle is 3.91^3 ft. would would i be after i add the 2nd baffle?
    Imtjnotu's Avatar
    Imtjnotu is offline Me Gusta Edition
    Nov 2006
    San Diego CA
    12,338
    134 Post(s)
    bro it would be the same as long as u put the mounting board on the outside of the box and not the inside
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,364
    137 Post(s)
    If you have a depth of 20, with 1 baffle, 18.5 of that depth is usable airspace.
    If you have 2 baffles, 17.75 of that depth is usable.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    buck.box.designs@gmail.com back up and running!!!
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - Batcap - DC - eD - Excessive Amperage - Rainbow - Shuriken
    In Nashville? Pm me.
    Apr 2009
    6,436
    6 Post(s)
    just put it on the outside of your top layer like i said in my first post.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
