Results 1 to 13 of 13
Reload Thread: Box Help
    Dmurria's Avatar
    Dmurria is offline Member
    Jun 2011
    San Antonio, TX
    45
    Box Help
    Ok I'm designing my own box using Google Sketch up and Re Box Calculator, I'm making an box for 4-18" Fi BTLs and was wondering could I have the Tuned Frequency at 20Fb for daily use. I'm going to be using it at shows and was wondering if it would be loud. If it helps its going in an 2007 Expedition EL Firing upward. I dont want to wall it because I'm like being able to look at the rear.
    bgowdy31's Avatar
    bgowdy31 is offline IF YA SMMMEEELLLLLLL!!!!
    Apr 2011
    Campbellsville, Ky
    4,505
    61
    8 Post(s)
    Re: Box Help
    good choice for the box design. but that may be a bit low. if it were m & this is only IMO i would go about 31. so are you going to be competing in spl?
    YOUTUBE SEARCH- *BGOWDY31 or BGWDY3131(<-new)* FOR ME & MY WIFEYS DAILY SYSTEMS
    MY 95 CHEVY BLAZER~~~~WIFEYS 03 FORD FOCUS SE
    1 SUNDOWN ZV3 18 D2(COMING SOON)~~~1 KICKER L7 15 D4
    4.76 CUBE 1 8" AEROPORT 41HZ~~~5.6 CUBE L-PORT 42-ISH-HZ
    CRESCENDO BC3500 @ 1 OHM~~~KICKER ZX1000.1 @ 2 OHM
    DC 220A,4-0GA RUNS,2GA BIG 3,3 DEKAS 105AH EACH~~~STOCK ALT,1-8GA RUN,STOCK YELLOW TOP
    147.6-MUSIC AVG 45 SEC(PREVIOUS AMP/SUB)~~~143.8-MUSIC AVG 45 SEC
    146.8-LEGAL MUSIC AVG(PREVIOUS AMP/SUB)~~~143.1-LEGAL MUSIC AVG
    Dmurria's Avatar
    Jun 2011
    San Antonio, TX
    45
    Re: Box Help
    Also I'm going to powering them with a Hifonics HFi3000D one per subwoofer, wired at 1ohm.
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    Buck is a Supporting Vendor of the forum!
    May 2008
    Nashville
    17,405
    138 Post(s)
    Re: Box Help
    Ok, please don't use RE box calculator for a setup of that intensity, that would be a disgrace. It's not as accurate as I'd like it to be.
    Bought from: kmanian(x2), KyleBetchtold, Rio, 05_ZX636, SoCalNoob, dave_damage
    Traded with: cj407, twistedchild420
    Sold to: jadon087, dvldogyut, 95saturn, many box designs...
    Click for High Output Enclosures Email (formerly Buck Box Designs)
    I do sealed, ported, t-line (consistent width), 4th and 6th order bandpasses.
    I answer any audio questions sent to my email for free.
    Alpine - AT - ASE (local) - Batcap - DC - eD - Excessive Amperage - Powermaster - Rainbow
    In Nashville? Me too! Pm me and come hangout!
    bgowdy31's Avatar
    Apr 2011
    Campbellsville, Ky
    4,505
    61
    8 Post(s)
    Re: Box Help
    i use 12volt.com... its actually very acurate... nice amp choice. ive been told they are a tad bit over rated. but not by much. but yea id still say 31
    Buck's Avatar
    May 2008
    Nashville
    17,405
    138 Post(s)
    Re: Box Help
    And don't tune to 20hz, lowest I would would be 26, but I would do 28-29 hz.
    Dmurria's Avatar
    Jun 2011
    San Antonio, TX
    45
    Re: Box Help
    Why shouldn't I tune to 20hz or use the RE calculator
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Re: Box Help
    Quote Originally Posted by Dmurria View Post
    The sub just isn't made for a low tuning like that. Tuning that far below the sub's fs is going to cut your box efficiency. Unless you plan on playing only stuff in the 20's, there's no need to tune that low. Keep tuning in the 30-33hz area and you'll be able to dig down to 25hz with those subs, which is plenty low for pretty much any music. Also, you're going to need more than a single layer of MDF on this thing, and ample bracing as well, something that the RE calc can't take into account for.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  9. #9
    Dmurria's Avatar
    Jun 2011
    San Antonio, TX
    45
    Re: Box Help
    Ok thanks, I'm going to tune it to 29Hz. The box is going to be 7ft3 for each sub, with an double baffle. How do you get a mirror finish with out using fiberglass
  10. #10
    May 2009
    Nebraska
    2,908
    14 Post(s)
    Re: Box Help
    Quote Originally Posted by globalminds_ent View Post
    people think that companies are so much better than each other when it comes to amps, but this is all a game people..all of this **** is the same, now some are better than others but in the end all of this **** is the same. These companies want u to fight over who is the best. When honestly there is probably 2 or 3 huge companies that make every single amp on the planet. Wake up people.u don't no who owns this stuff and u don't know who owns these build houses.
    Quote Originally Posted by benbenondatrack View Post
    you dont even got no swag anyway
  11. #11
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Re: Box Help
    You're going to need to at least do doubled 3/4" material on the entire box. A big, low-tuned box like that will want to tear itself apart if not built right.
  12. #12
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,078
    348 Post(s)
    Re: Box Help
    Quote Originally Posted by RAM_Designs View Post
    exactly, if you don't want to use twice the MDF you can do other types of bracing, but you need to be sure to do it right or you will wind up with a broken enclosure very quickly.
  13. #13
    Nov 2009
    Linton,In.
    86
    Re: Box Help
    28 cubes and dbl mdf and he still wants to see out the back?
