Results 1 to 9 of 9
Reload Thread: 2 subs 2 amps vs 2 subs 1 amp
    nutznboltz's Avatar
    nutznboltz is offline Junior Member
    Mar 2011
    colorado
    15
    is there a down side to having two identical subs with two identical amps?
    one sub hooked to one amp and another sub to another amp, running in the same box.
    heard both ways, that the amps, even though are the same, will put out a couple watts difference, which will throw off the subs a little, not enough to REALLY notice, but, their not at their full potential. then someone else told me, don't matter, same amp, same power, set same gain, no problem.
    CRXBMPN's Avatar
    CRXBMPN is offline Moe Bass
    Jul 2004
    Maine
    37
    8,922
    45
    1 Post(s)
    353 Post(s)
    Re: 2 subs 2 amps vs 2 subs 1 amp
    well if you have two subs to one amp, the impedence to that amp would be halved due to 2x the coils in parallel I'd assume, compared to two amps two subs. You may see a similar # from one amp @ 1/2 the imp as two amps on two subs, due to less elec strain, power compression if the sub cant handle the one amp to its fullest, etc.
    I like having one or more amps per sub, myself
    Team Bass Lovers Of MainE/The Loud Crowd/CentralMaineBassHeads
    2k5 SLAP Stock 2 National Champion - I feel old...!
    2009 Mazda 5 Mini Van - Shocker/Sundown 12s + 2x Sundown NS1 = 155.3 p.b. so far...
    burzendowski's Avatar
    burzendowski is offline CarAudio.com Elite
    Jul 2008
    CA.COM
    1,315
    3 Post(s)
    i prefer one large amp
    Refs: cheeseburger, miles0803,fatboyracing,bobtista,joeybutts,22mounta ineer
    feedback thread http://www.caraudio.com/forum/showthread.php?t=425693
    jonny101abc's Avatar
    jonny101abc is offline SOCAL Stang-Man
    Jan 2005
    San Diego Punks!
    33
    1,751
    10 Post(s)
    multiple subs on multiple amps myself
    05trailblazer's Avatar
    05trailblazer is offline k33p groaning son :)
    Mar 2011
    Dallas,TX
    2,048
    194 Post(s)
    Icon6 Re: 2 subs 2 amps vs 2 subs 1 amp
    i prefer having to large amps to two 18s!!
    Chriszle's Avatar
    Chriszle is offline CarAudio.com Elite
    Jan 2011
    SD
    1,718
    373 Post(s)
    If your going to run 1 amp to 2 subs, you will see more box rise, whereas if you run 2 amps strapped to 2 subs, the amplifiers will share the rise effectively reducing the amount of rise the amp sees. All of this of course can be accounted for when designing the system, but it is just food for thought.
    Chriszle's Avatar
    Jan 2011
    SD
    1,718
    373 Post(s)
    Also if your going to run 2 amps and not strap them, make sure the gains are set with a DMM or O-scope, or you will have some cancellation.
    nutznboltz's Avatar
    Mar 2011
    colorado
    15
    ^ box rise? strap?
  9. #9
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    there are a lot of factors that determine which way it is better,
    what vc config are the subs,
    what is their power handling.
    what power do the amp/s put out.
    and what imp do the amps do rated power.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
