Results 1 to 13 of 13
Reload Thread: Cut sheet
    MANTI5's Avatar
    MANTI5 is offline CarAudio.com Elite
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Cut sheet
    Anyone know an easy to use program that will make cut sheets?
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    Re: Cut sheet
    your brain.
    its not that hard to figure out really,
    what are the dims of your box and i can help you out.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
    MANTI5's Avatar
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Re: Cut sheet
    Something along the lines of H: 14, W: 16, D: 12
    Jun 2010
    4,064
    350 Post(s)
    Re: Cut sheet
    ported or sealed?
    if its sealed then the top and bottom can be 16x12, front and back can be 12.5x16, and the sides can be 12.5x10.5
    it all depends on where you want the joints showing though.
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Re: Cut sheet
    It is best to get the enclosure lined out how you want it(design it) then figure out cut sheets
    MANTI5's Avatar
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Re: Cut sheet
    Thanks and it will be sealed.
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    Re: Cut sheet
    Quote Originally Posted by MANTI5 View Post
    If you are going sealed then you need figure out what subs you will be running and what type of sound your looking for out of them. This information will allow you to figure out the amount of air space needed for your application.
    MANTI5's Avatar
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Re: Cut sheet
    I'm looking to build around 1.5 cubes sealed for a shiva x2, feeding it aound 800 watts rms.
  9. #9
    Jun 2010
    4,064
    350 Post(s)
    Re: Cut sheet
    you a good bit on the small side. your at 1.1 before displacement with that one.
  10. #10
    bumpin buick's Avatar
    bumpin buick is offline Science is everything
    Jul 2007
    Appleton, Wisconsin
    11,023
    1 Post(s)
    Re: Cut sheet
    I use cutlist plus, if you are a torrent guy you should look for it, they have a free trial download as well
    http://www.caraudio.com/forums/buyer-seller-feedback/305521-official-bumpin-buick-feedback-thread.html
  11. #11
    MANTI5's Avatar
    Nov 2010
    Southern AZ
    1,434
    1 Post(s)
    40 Post(s)
    Re: Cut sheet
    Quote Originally Posted by Phoenix Risen View Post
    Not if those are internal measurements, at least not according to the calculator I was using.
    I'll check out cutlist plus, thanks.
  12. #12
    Jun 2010
    4,064
    350 Post(s)
    Re: Cut sheet
    if those are internal then your box dims are actually 15.5Hx17.5Wx13.5D
  13. #13
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Re: Cut sheet
    Cut sheets, meh.
    2,500+ designs since March 2011
