Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Reload Thread: Alright SPL guys, what is the deal with the dowel rods in large enclosures?
    SPLAudioHz's Avatar
    SPLAudioHz is offline Senior VIP Member
    Sep 2010
    Indiana
    389
    17 Post(s)
    Obviously I am not an SPL guy, but I am going to attempt my first setup. I am seeing a lot of different enclosures, but most have 2x4s, dowel rods, and 1x1" pieces to create support from many different angles. What is the functionality and where is it ideally good to use it? Thanks!
    Jesse
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    Re: Alright SPL guys, what is the deal with the dowel rods in large enclosures?
    the answer to that question changes for car to car and box to box.
    they are there to make sure that the box doesnt flex which will cause you to loose dbz. you just have to play work with it in your specific setup to figure out what works for it.
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
    BlactimusCrime's Avatar
    BlactimusCrime is offline NUT HUGGERS UNITE!!!
    Jul 2010
    Your mom's port, OH
    27
    3,061
    77 Post(s)
    the supports are most important with a box with large area sides, or with high power/large cone area setups
    Quote Originally Posted by loudrc View Post
    fuck you eddie.
    Quote Originally Posted by dbeez View Post
    Judge me not by what i've done but the amount of haters on my balls.
    Quote Originally Posted by CRXBMPN View Post
    you have the best user ID on teh site playa
    Refs: NateBerrier, Thegreatestpenn, mossberg385t, mfenske, plugitin, retroaudioinc, michaellane, Ge_off_me
    Feedback- http://www.caraudio.com/forum/buyer-seller-feedback/489798-bumpinboats-feed-back-thread.html#post7273394
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    When I do an SPL enclosure it depends more on the size of the enclosure and tuning. If it is a lower tuned then i will use a 1" dowel for ever 12" squared of space(not perfect just eye ball it), if it is tuned higher then some times you can skimp a little. If I'm using a ton of power then I brace the hell out of it then do a few test burps to see were it flexed then brace more. lol
    It is all dependent on some many things. Some subs even like it when the box flexes a little..just one of those things you have to test and play with.
    bhsdriller's Avatar
    bhsdriller is offline CarAudio.com Veteran
    Jul 2007
    bakersfield,ca
    4,491
    344 Post(s)
    They keep the panels from flexing. Longer/larger panels need it more than shorter one's
    Team Flex Issues
    4 18" Mayhems
    2 bc5500's
    Bought from: ameduce(x2), Hatchet_Warrior, jeeper07,DB_DRAG_SPL,ssackett, lyttleviet,MillzThaYungin, blackbonnie, ryan1126, Goindef154(x2), Lonnie, dave_damage
    Sold to: Ilovebass, nismos14, chednompton, teen, jonesy
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,867
    2341 Post(s)
    My box is braced to keep it rigid...
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Kenwood DNX-692HD_____________ -Head Unit: Eclipse CD7100
    -Sub Stage: Focal KX40 16"_________________ -Sub Stage: Looking
    -Mids/Highs: Focal KRX & PHD AF____________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: Mosconi AS200.4_________________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: Mosconi AS200.4_________________ -Mid Amp: ^^^
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    They're just used to brace the larger and more necessary pieces of the box. Window braces this this work great because you can use one piece of MDF to brace four walls.
    But dowels or all-thread would probably be better for spl setups to allow for smoother air flow around the bracing structure. For daily though, where you're not chasing numbers, window style braces work great from my experience.
    2,500+ designs since March 2011
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,639
    24 Post(s)
    1921 Post(s)
    already answered a form of box brace to stop enclousure flex
    ---------- Post added at 10:58 PM ---------- Previous post was at 10:57 PM ----------
    Quote Originally Posted by RAM_Designs View Post
    you have some nice looking box designs
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  9. #9
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by Louisiana_CRX View Post
    Why thank you. I've been crazy busy lately...got 4 more design requests today. I need to crank at least a couple out tomorrow to try and catch up.
  10. #10
    SPLAudioHz's Avatar
    Sep 2010
    Indiana
    389
    17 Post(s)
    Outstanding feedback. Bout to boot up CAD 11 and design something. RAM you have a PM.
  11. #11
    Heeltoeclutch's Avatar
    Heeltoeclutch is offline CarAudio.com Elite
    Jan 2011
    San Diego, CA
    27
    1,256
    8 Post(s)
    Saw 1" dowel the other day $3 cheaper at michaels than home depot per 36 in.!!
    Gonna hafta remember that if I ever get around to trying glass.
    Feedback-ness
    http://www.caraudio.com/forums/buyer-seller-feedback/503302-heeltoeclutch-feedback.html
  12. #12
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by Heeltoeclutch View Post
    Try to stick with 1.25-1.5". A good way to get a larger bracing point is to cut your dowel 1.5" shorter than the span you're bracing. Use a hole saw to cut 2.5-3" diameter circles out of MDF to put on each side of the dowel, and you have yourself more surface area contact than a 2x4 while taking up 1/3 the space.
  13. #13
    slim2fattycake's Avatar
    slim2fattycake is offline rolling right along
    Jun 2008
    In the Stars
    2,192
    158 Post(s)
    best way to say it is, you want to break largest panels down in size first.
    SPL-Lab REP
    Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has more features and support? PM me.
  14. #14
    SPLAudioHz's Avatar
    Sep 2010
    Indiana
    389
    17 Post(s)
    Does the dowel and MDF used as support need to be subtracted from the air space?
  15. #15
    Jun 2008
    In the Stars
    2,192
    158 Post(s)
    yes
    SPL-Lab REP
