Results 1 to 14 of 14
Reload Thread: 15" Re SX in a 4-door Honda Accord
    SPLmatic's Avatar
    SPLmatic is offline word
    Mar 2010
    Lincoln, NE
    166
    Looking for some box ideas from those of you that know more about them than I do. I'm running a Resonant Engineering SX 15" in my Accord on ~1300 rms in a temporary box. I'm curious as to how I can get this setup to sound the clearest and loudest. Although the SX isn't the greatest sub for it, I'm trying to gear this more towards SPL. Right now the sub is facing up and the port is facing the cabin.. just experimenting at this point.
    I have quite a bit of trunk space, I was able to fit an Fi BL 18" in there in a 6 cuft. box.. and I was also able to get them out of there. Not exactly sure the dimensions of the box in there right now, but you can use your imagination dimension-wise if you have the kindness to come up with a design for me. I'm thinking I want the sub and the port on the same side, facing the back of the car. Or should I point them towards the cabin? Seats fold down.
    Thinking about the tuning being around 35hz. I also plan on putting a couple layers of deadener in my trunk to improve the sq a bit.
    any ideas, input, advice?
    slim2fattycake's Avatar
    slim2fattycake is offline rolling right along
    Jun 2008
    In the Stars
    2,169
    7 Post(s)
    Re: 15" Re SX in a 4-door Honda Accord
    what year accord?
    SPL-Lab REP
    Want an SPL meter for a lot less than the cost of a Termlab, but just as accurate and has the same features? PM me.
    SPLmatic's Avatar
    Mar 2010
    Lincoln, NE
    166
    Quote Originally Posted by slim2fattycake View Post
    what year accord?
    2001
    s10's Avatar
    s10
    s10 is offline Member
    Feb 2011
    British columbia canada
    69
    point it towards the back, port towards the back aswell, L port box. is probubly the best... i have the srx 12 in my truck. pointing the back of the cab, and i have tryed with a type r 15, in a prelude, towards the back with the L port will give u clean and Hard Hard Hard hitting bass!
    Jun 2008
    In the Stars
    2,169
    7 Post(s)
    i know the 6th gen is a little different but my 5th accord was loudest sub back port driver or sub forward port passenger without sealing off. you can build it and just flip it to try and see if there's a different if you wanted.
    SPL-Lab REP
    Oct 2005
    Beatrice, NE
    25
    654
    Sub Back, Port Back.
    Almost all trunk cars sound best with this configuration IMO.
    Now the only question left is what tuning you'll go with when I build your next box. I'm personally recommending 28-30 hz.
    Ride: 1993 Mazda MX-3
    HU: Alpine CDA-9853 with KCA-420i iPod Interface
    Front Stage: Pioneer Premier TS-D602P
    Sub Stage: TC Sounds LMS-R 15 Dual 2 in 4 cuft. box tuned to 24hz
    Front Amp: Precision Power PC2400.2. 100rms x 2 at 4 ohms
    Sub Amp: Powerbass XA 1500d. 1500rms x 1 at 1 ohm
    Refs:
    Sold to: 99StangGt, Kagymp5, DMDAKOTA, Snozzer, spljunkiems, jblanford, 98dodgestratus, stishdr, kombat96
    Bought from: allenzo, BreakMyWallet, pickup1, defj, select127
    Mar 2011
    St. Pete, Fl
    96
    The best solution for your application is to build a bandpass. These are usually not sell received by most customers due to ?????(not really sure why), but a bandpass allows you to focus your sound(thru a ski port, back deck,etc). There is no lost energy in your trunk, it is all in your cab. If built properly it is very musical with a Db gain similar to a ported box. If built wrong, it sounds like **** and everyone thinks they ****. I have done 2 of these in a bandpass before and it was rediculous. One other cool thing about a bandpass is it cleans up the funny sounds that most loud woofers make and actually makes the woofer more efficient based on design so a woofer that requires 1000 watts can perform almost the same with 500-600 watts in most applications. A good real life example of this is I took a CTS-V that had 2 solobaric 12" woofers in a ported box. It metered 145.8 with a 1000 watt amp. I built a bandpass that unloaded thru the "ski port" and it metered 148.5 with the same power. A drammatic improvement. Hope this helps!
    Quality is derived from experience and time, not price.
    Oct 2005
    Beatrice, NE
    25
    654
    Quote Originally Posted by BASSMEKANIK89 View Post
    Dude... /yourself.
    Funny sounds? Only thing funny is the nonsense coming from your post.
    Bandpass may be louder but the average daily driver doesn't need a setup like this.
    Refs:
  9. #9
    Rich00's Avatar
    Rich00 is offline Where da white women at??
    Mar 2004
    springfield mo
    33
    592
    From my experience with trunk cars sub back port back and deaden your trunk so it doesn't rattle.
    refs- glowin3232(RE SE 12"), blue-accord(MTX 5400x), RMKrider1(traded stuff), Goodtimes(alpine 9815), ez2hotwire( RE SE 12") wizkid (orion co435)
    2009 civic SI
    Stock "premium sound" HU with a custom mercman factory amp bypass harness
    Front stage: Boston sc65 with stock tweets
    Jl audio xd500/3
    Fi X 10" sealed or a 2012 Alpine type S 10 ported?
  10. #10
    Mar 2011
    St. Pete, Fl
    96
    Quote Originally Posted by matt_martin87 View Post
    Dude... /yourself.
    You must be referring to yourself in that you dont think you need it, but its nice to offer the best option for what he is trying to do. As far as "funny sounds", i was reffering to the not so great noise you hear from a sub under high excursion. In a bandpass you cant hear that. Most people don't even notice it, but it is there. If he had a vehicle with a hatch or cargo area I would not have even mentioned it since it would not help a whole lot, but for a trunk it is the first option i offer everyone. BTW if your going to attempt to bash me about my post being nonsense, its best not to agree with my post in the next sentance....
  11. #11
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Lol at this thread.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  12. #12
    tc300's Avatar
    tc300 is online now CarAudio.com Veteran
    Mar 2007
    springfield,ill
    2,195
    2 Post(s)
    op, did you not like the BL 18 you had in there..??
    i would pick a BL over an sx....
    MODS
  13. #13
    09civic's Avatar
    09civic is offline CarAudio.com Veteran
    Dec 2010
    Melbourne, FL
    6,690
    33 Post(s)
    Quote Originally Posted by tc300 View Post
    Dr.subwoofer's apprentice?
    2009 Honda Civic 5 speed
    Alpine CDA 117
    CDT HD 61's
    AB SQ500
    AB VFL 8" on 500RMS
    0.85 @ 32 Hz
  14. #14
    SPLmatic's Avatar
    Mar 2010
    Lincoln, NE
    166
    I had it for a year and wanted something new. I would have kept it if I could have thrown maybe 2000 rms on it, but my electrical can't keep up with that at the moment. Plus there was just no room for that sub to breathe, took up my entire trunk. Too much rattle. The SX definitely sounds better and louder, just because there's more room in my trunk.
