Results 1 to 5 of 5
Reload Thread: Mounting a Sub on plexiglass....
    Omarvelous's Avatar
    Omarvelous is offline CarAudio.com Elite
    Jan 2004
    Queens, NY
    33
    1,371
    Was wondering if there is anyone that would know much about mounting a sub on plexiglass?
    The sub will either be a 12" XXX or 15" XXX.
    Was wondering if
    - 3/4" Plexiglass would be sufficient, and i could mount the sub on top OR
    - Do a double baffle using 2 3/4" layer sheets of plexiglass, and mount on top OR
    - Use 2 3/4" sheets, one for the mount hole (14 1/8" for the 15" for example) and the other to flush mount sub(the other at about 15 1/8" for the 15")?
    The box i'm building will be a mix of fiberglass/mdf/plexiglass
    Just a possible thought for now.
    Thank you!
    nweibley's Avatar
    nweibley is offline this:annoyinginsomanyways
    Jan 2004
    Tampa, FL
    31
    471
    1 Post(s)
    Re: Mounting a Sub on plexiglass....
    http://www.bcae1.com/plexi.htm
    3/4" should be fine, because plexi is slightly stronger than MDF, but be very careful.
    Also, remember plexi is very expensive. I just got a KILLER deal on 3/4" thick plexi, I got 1' x 2' for $20, only because it was leftovers and the company is moving facilites and needed to get rid of all their drop cuts... so it pays to call around I guess...
    Good luck with the pelxi!
    -----Nate
    If my Avatar doesn't make sense to you: Click Here
    hakuna matata
    Omarvelous's Avatar
    Jan 2004
    Queens, NY
    33
    1,371
    Yea all i really need is like not even 2' x 2'. Plus my boy that lives in chicago leave right next to one of the largest plexiglass producers, and can get it dirt cheap.
    So you suggest my first suggestion
    nweibley's Avatar
    Jan 2004
    Tampa, FL
    31
    471
    1 Post(s)
    Yeah, I mean, a small 3/4" sheet is pretty **** strong, especially if the magnent is hanging down like that. If you were going to be facing it rearward or wanted to be more careful, 1" thick plexi should be plenty, but again, be REALLY careful mounting it and cutting the hole for the sub and everything... this is not something you want to do twice.
    hakuna matata
    sound Q's Avatar
    sound Q is offline Junior Member
    Feb 2004
    Sun Valley
    43
    22
    By the way how do those soundstream turantulas sound?
  1. mounting depth question
    By plyhammer in forum Enclosure Design & Construction Help
    Last Post: 01-31-2004, 10:40 AM
  2. another plexiglass question...
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 01-23-2004, 07:20 AM
  3. plexiglass...
    Last Post: 01-20-2004, 02:24 PM
  4. plexiglass
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-14-2003, 11:36 AM
  5. speaker flush mounting
    By desi_daru in forum Wiring, Electrical and Installation Help
    Last Post: 12-02-2003, 05:49 PM
