Results 1 to 2 of 2
Reload Thread: Felt over fiberglass
    1BadHawk's Avatar
    1BadHawk is offline Member
    Oct 2002
    Here
    43
    100
    Can you put fleece on top of fiberglass? Im wondering if I use a thin material such as aT-shirt, soak it with resin, then lay fiberglass on top of that.... then to help make life easier put fleece on top of the glass. Some bondo and sand.
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    Re: Felt over fiberglass
    I doubt that would be strong enough for any load
  1. Is there a good book on fiberglass?
    By CWT in forum Enclosure Design & Construction Help
    Last Post: 02-02-2004, 11:23 PM
  2. What do you do if your fiberglass hardenecd but there are alot of air bubles?
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-15-2003, 10:57 PM
  3. How thick should my fiberglass enclosure be?
    Last Post: 10-12-2003, 11:07 AM
  4. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
