Results 1 to 2 of 2
Reload Thread: Help on box size???
    620hpcrx's Avatar
    620hpcrx is offline Senior VIP Member
    Jan 2004
    Bellingham, WA
    206
    Icon32 Help on box size???
    I have 2 12 inch sony xplods and Im building a ported box in shop but I cant compute the data given by winisd or anything else to determine the LxWxH of the box. The space thats recomended in a ported box is 1.56cu/in per sub and a 3"x8" port. here are most of the other specs
    Frequency Response: 18 - 2000 Hz
    Sensitivity: 89 dB/W/m
    Impedance: 4 ohm
    d (mm/inch): 250/9.8
    Rdc (ohm): 3.2
    Fs (Hz): 26.4
    Qts: 0.42
    Qes: 0.44
    Qms: 5.86
    Vas in litres: 55.5
    Vas in cu.ft: 1.96
    Mms (g): 219.0
    Lvc (mH): 1.2
    Xmax (mm/inch): 7.5/0.3
    BL (Tm): 16.1
    Could someone help me with the size of the box in LxWxH???
    620hpcrx's Avatar
    Jan 2004
    Bellingham, WA
    206
    Re: Help on box size???
    http://www.carstereo.com/help/Articles.cfm?id=17
    When I put in the info here it tells me that I need 4.8cu ft of space for my 2 subs. Is that right? And when start building should I put a wall between the 2 chambers?
  1. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  2. whats a good size sealed box for 12 eD sub
    By frozenfire89 in forum Enclosure Design & Construction Help
    Last Post: 01-11-2004, 07:30 PM
  3. good size for ported box for 12'' SE/Magnum
    By Matador in forum Enclosure Design & Construction Help
    Last Post: 01-07-2004, 02:27 AM
  4. Bass box size
    By Sharp_Shoota in forum General Discussion
    Last Post: 10-20-2003, 09:04 PM
  5. Ported box size for a Type R 10"?
    By supernoodles in forum Enclosure Design & Construction Help
    Last Post: 10-13-2003, 11:32 PM
