Results 1 to 2 of 2
Reload Thread: Dual 12 in snail shell enclosure?
    620hpcrx's Avatar
    620hpcrx is offline Senior VIP Member
    Jan 2004
    Bellingham, WA
    206
    I need plans for a snail shell enclosure to hold 2 12 inch Sony Xplodes. Here are the specs on the subs.
    vas=55.5
    fs=26.4
    qts=.42
    xmax=7.5
    The recomended volume for a ported box is 1.58cu ft per chamber with a 3in wide 8in long port for each.
    If someone could dig up some plans for this that are close to the specs please post it.
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Re: Dual 12 in snail shell enclosure?
    Good luck man. :thumbsup!
    The guys at P4S won't let their plans out for free. Snail Shells(DUAL= Double Shot) are designed specifically for the subs. There are some threads w/ single woofer plans out but you would have to play around with them to get them to work. Start here - http://www.caraudio.com/vb/showthrea...ht=snail+shell I hope this helps you!
  1. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 06:15 PM
  2. Snail shell enclosures....
    By Trixter in forum Enclosure Design & Construction Help
    Last Post: 01-19-2004, 12:27 AM
  3. snail shell box?
    By fatt_man in forum Subwoofers
    Last Post: 01-17-2004, 03:47 AM
  4. Dual 15a Enclosure
    By BumpinDoug in forum Subwoofers
    Last Post: 10-18-2003, 01:51 AM
  5. Dual 15a Enclosure!!!
    By DoubleR in forum Enclosure Design & Construction Help
    Last Post: 08-10-2003, 02:22 AM
