Results 1 to 9 of 9
Reload Thread: 2 12's Ported or 2 15's Sealed
    azphat12's Avatar
    azphat12 is offline Senior VIP Member
    Feb 2010
    Tulsa, OK
    263
    I just bought a new car and need to redo my subs and enclosure.
    Here is my question..
    I have a 1250 watt @ 1ohm Rockford Fosgate T1000bd
    With my 1250 watts what would be better....
    2 12's in a ported box around 3.5 cu ft
    or
    2 15's in a sealed box around 5 cu ft.
    I am planning on getting SA 12's or SA 15's. Just wondering which would be best. Both speakers are rated at 600rms. I am sure they can take more, and maybe down the road I can get another amp. But for now I have the Fosgate T1000bd to work with.
    If the recommendations are for the ported. Anyone have a basic box layout? I built one for my Explorer, but the height is too much for the trunk.
    I was thinking something similar to
    SQP212 - Ground Shaker 12" Dual Ported Box
    # 12" Dual Ported Box
    # 3/4" MDF Construction
    # Volume: 1.8 cu. ft. Per Chamber
    # Width: 32"
    # Height: 13.5"
    # Depth: 19.25
    But I would build it myself. If those are good for the SA12's then all I would need to know is where to add some in order to get some bracing in there and maintain the cu ft.
    I am looking to make this move around February when taxes get here...if the gov is still giving taxes, lol.
    Thanks for any help. I really do appreciate it!
    I will be searching to see if I can get any answers that way as well.
    azphat12's Avatar
    Feb 2010
    Tulsa, OK
    263
    Re: 2 12's Ported or 2 15's Sealed
    Well....looking around maybe even the SA12's in a sealed box? I listen to all types of music. Rock, Rap, Metal, Bass.
    When I have subs in I probably listen to Rap/Bass 70% and Rock/Metal 30%. If that would alter anyones opinion as to which setup would be the best.
    I am staying with Sundown SA subs though.
    Also, I am not looking for SPL. I want these to get loud, but not sound like crap doing it.
    pro-rabbit's Avatar
    pro-rabbit is offline Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    36
    12,395
    2 Post(s)
    2522 Post(s)
    12s in ported box in most cases. I would also do one larger port instead of two smaller port.
    azphat12's Avatar
    Feb 2010
    Tulsa, OK
    263
    That is what I did on my current box. Why would you recommend 1 port?
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Quote Originally Posted by azphat12 View Post
    More efficient than two smaller ports and takes up less box volume.
    2,500+ designs since March 2011
    Feb 2006
    Rockwall, TX
    32
    21,086
    4 Post(s)
    457 Post(s)
    Pair of SA12's, 3.5ft^3 at 30hz.
    azphat12's Avatar
    Feb 2010
    Tulsa, OK
    263
    Here is what I came up with....
    Can anyone tell me if this would be accurate for 3.5 @ 30hz.
    Wood = .75
    W = 36
    H = 15
    D = 18
    Port 1 = Length 14.25
    Port 1 = Width 3
    Port 2 = Length 7
    Total port length 26.5
    It shows this would be 3.8 @ 29.99
    Figure with some bracing that would come down closer to 3.5?
    speakerdude123's Avatar
    speakerdude123 is offline Senior VIP Member
    Aug 2010
    WA
    200
    14 Post(s)
    If your using 6by6's for bracing then ya it would take you down about 0.3 cubes. I couldn't imagine bracing taking up more than 0.1 cubes. So I would say more around 3.7.
    That is unless you factored in the displacement of the drivers and that's how you got 3.5, then yes 3.5 would sound about right.
  9. #9
    azphat12's Avatar
    Feb 2010
    Tulsa, OK
    263
    Actually I do not think the displacement was calculated.
