Results 1 to 4 of 4
Reload Thread: looking for blow thru cut through help, adjustable port for spl /daily any ideas?
    burzendowski's Avatar
    burzendowski is offline CarAudio.com Elite
    Jul 2008
    CA.COM
    1,315
    3 Post(s)
    so i have been thinking it would be sweet to have an adjustable port in my cut through. im doing 2 15's in a silverado and would like to use it for daily and spl by swapping or adjusting the port. does anybody have any ideas that they would be willing to share???
    i was thinking a large short port built into the box and a longer less square inch port to slide in the large port to drop tunning....
    Refs: cheeseburger, miles0803,fatboyracing,bobtista,joeybutts,22mounta ineer
    feedback thread http://www.caraudio.com/forum/showthread.php?t=425693
    whitedragon551's Avatar
    whitedragon551 is online now Moderator
    Mar 2009
    IL
    13,601
    43 Post(s)
    1434 Post(s)
    Re: looking for blow thru cut through help, adjustable port for spl /daily any ideas?
    There was a box build here that someone just did with an adjustable port. I cant seem to find the thread though with the pictures.
    Found it:
    The $500 dollar 4 15's build
    CA.com FAQ's
    CA.com TOS Agreement
    Forum Rules
    HU: ///Alpine 9887, KCE-400BT, KCE-433IV, KTX-100EQ Imprint, 8Gb iPod Touch
    Front Mids: Eclipse SC6500
    Front Tweeters: Morel made Xtant 28MM Silks
    Subs: Audiomobile Evo 10" TC2+
    Enclosure: 1.1 Cubes sealed with 10 Ounces Poly Fill
    Amp: Audio Systems Twister F6 380 III
    Phoenix Risen's Avatar
    Phoenix Risen is offline OG.... Original Ginger
    Jun 2010
    Dayton/Springfield, Ohio
    4,064
    350 Post(s)
    you could always use aeros, just have 2 sets of tubes at different lengths so you can swap them out. you can easily use t nuts and small hex head bolts to hold the ports in place
    R.I.P. 2008 Hyundai Tiburon GS
    2005 Subaru Baja turbo, build in planing stages.
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    27
    6,382
    17 Post(s)
    Cool, I'm doing two 15's in my Dakota. I'm doing a 6th order, so hypothetically I could make the front port removable to put in place a larger and shorter port. The same applies to a 4th order
