Results 1 to 4 of 4
Reload Thread: vent match in WinISD
    Matador's Avatar
    Matador is offline -= StillBumping =-
    Oct 2002
    Ca
    2,093
    i dled winisd beta version, the old one. cuz the pro alpha dosn't let u change the box dimensions.
    anyways, when i try to figure out teh vent size, there's a vent match in the bottom. does that need to be 0 or as close to 0 to have an optimum port?
    also, i seen ports that are L shaped. if the length of the port is like 30, n the box i only 20'' deep. how would dat work?
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    www.angelfire.com/falcon/matador updated 5/02/03
    [email protected]
    runningame21's Avatar
    runningame21 is offline beyond recognition
    Jan 2004
    Albuquerque, NM
    35
    68
    Re: vent match in WinISD
    below .10 is usually what I hear is best for the mach. Mine is at .04. The L shaped port can be measured the same as a straight port. If the box is 20". and you need a 30"port, then the L wiould be 20" on one side, then 10" on the other. Its quite simple. DONT FORGET TO FIGURE IN PORT DISPLACEMENT.
    Matador's Avatar
    Oct 2002
    Ca
    2,093
    K, thanks. so if u do 20in in one side, n the other 10 goes perpendicular to it, you would keep the same width of the opening correct?
    Eclipse CD5444
    Momo MM6
    Arc Audio CXL-2100
    1 12'' RE HC
    Memphis MC-1000D
    [email protected]
    BAsK510's Avatar
    BAsK510 is offline Epitome
    Dec 2003
    Bay Area, CA
    32
    322
    correct...
    2002 Chevy Impala
    Kenwood KDC-MP5028 - Ascendant Audio Havoc 15" - 3.5 cuft 35hz - eD nINE.1 - 1/0 power - 100+ sqft deadener
  1. WinISD calculations
    By runningame21 in forum Enclosure Design & Construction Help
    Last Post: 01-21-2004, 07:47 PM
  2. winisd port calculations
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 01-01-2004, 09:50 PM
  3. To Vent or Not To Vent
    By .:Mark:. in forum Enclosure Design & Construction Help
    Last Post: 11-09-2003, 03:13 AM
  4. New WinISD Pro Kicks ***
    By Bavarian3 in forum General Discussion
    Last Post: 10-04-2003, 12:09 AM
  5. ?'s About vent dimensions?
    By MXJMR in forum Enclosure Design & Construction Help
    Last Post: 08-13-2003, 11:34 AM
