Results 1 to 12 of 12
Reload Thread: Fiberglass
    BlackFlux's Avatar
    BlackFlux is offline Junior Member
    Jan 2004
    Maryland
    Icon32 Fiberglass
    I know this isn't exactly about car audio but I'm getting ready to make a custom PC case. I was thinking about making the entire enclosure/box out of those green floral foam blocks.
    Now keep in mind I'm a n00bie. With that said here goes nothing: Which matrial should I use to harden the foam (I was thinking about coating/soak it with fiberglass resin)?
    I've done some research but I'm haven't found anything. I should also mention that the final enclosure should weigh just as much as a normal plastic case.
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    I'm trying to figure out what your wanting to do. The floral foam isn't going to work so well. I personally just use it to make a mold. By the time you carve away the foam to get the shape you want there will be nothing left structuraly. A carbon fiber case would look pretty cool.
    5 % equipment
    90 % install
    5% beer
    BlackFlux's Avatar
    Jan 2004
    Maryland
    Re: Fiberglass
    Carving?!?!?!
    Ok maybe this will help. The floral foam comes in blocks.
    Slice blocks. Then Glue. You end up with 6 pieces (3 for the top and 3 for the bottom). Glue 3 pieces together to form top. Then glue 3 more pieces to form bottom. Then apply Resin...
    I was also thinking of using balsa. You've seen it before its this stuff:
    Do anyone know if this would work?
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    Cut , carve, slice, shape how ever you get the foam in the shape you desire. I'm still trying to grasp what your after. The resin will stick to the foam, but the foam with just resin on it is not going to be very sturdy. The balsa wood seems to me a better, and stronger choice.
    5 % equipment
    90 % install
    5% beer
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    Are you going to use the floral foam as a mold to lay mat over top of ? Or are you wanting to use the foam itself ?
    5 % equipment
    90 % install
    5% beer
    BlackFlux's Avatar
    Jan 2004
    Maryland
    Re: Fiberglass
    I was going to use the floral foam as a mold and then I was going to apply fiberglass resin and mat over top of.
    Just worried how strong it would be and what would happen when I driller through it. Same goes for the balsa. I was also thinking of building a frame out of the balsa and then pouring some plastic resin down in it.
    Something like this:
    Any sugesstions?
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    Ahhhhhhhhhhhh I understand. I'm having a slow day Weight would depend on how many layers and what weight of mat. But you could make a case with fiberglass that would be twice as strong and as light if not lighter than a regular one
    5 % equipment
    90 % install
    5% beer
    BlackFlux's Avatar
    Jan 2004
    Maryland
    Re: Fiberglass
    I originally thought of using carbon fiber but thought it would be hard to play around with when it comes to cutting , carving, slicing, shaping.
    With the foam I would be able to do stuff like this:
    But your probably right about the it being stronger. Do anyone know of any good tutorials for carbon fiber?!?!
  9. #9
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    That's pretty cool man You can do that with mat, but it's going to take some serious work getting it into all of the crevices. You need a vacuum form machine, that would look sweet made out of plexi
    5 % equipment
    90 % install
    5% beer
  10. #10
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    36
    368
    Re: Fiberglass
    be careful..some foam will melt from resin
  11. #11
    MXJMR's Avatar
    MXJMR is offline Senior VIP Member
    May 2003
    Naptown, IN, US of A
    212
    Re: Fiberglass
    I dont know much about styrofoam but i have saw dash's built with i guess just regular styrofoam, then a nice layer of body filler and sand, then paint or what not.
  12. #12
    ramos's Avatar
    Dec 2001
    Virginia
    52
    10,329
    104 Post(s)
    Re: Fiberglass
    Polyester resin won't melt the green floral foam, UNLESS you mix it way hot.
    5 % equipment
    90 % install
    5% beer
  1. check out my fiberglass box *PIC*
    By subboxmaker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2004, 03:14 AM
  2. How thick should my fiberglass enclosure be?
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-12-2003, 12:07 PM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 01:08 PM
  4. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 06:03 PM
