Re: help on slot ported box
Originally Posted by
El_dorado ok lets start, ok my dimme. in my car are 38" wide by 15" height & 17 depth. I want to make a slot ported box since I think I'm almost got an idea already., the thing is how long do I make the port & how height & depth ok here's an eg.of enclouser (this will be for 2 hx2 dvc 4omhs rfd-2212) I think came out 4.8 cub. total - .75 of wood included
(2x) 38" by 17" top & bottom
(2x) 38" by 15" back & front parts
(2x) 15" by 17" sides
all made of 3/4 or 19mm mdf,, are this dimm. ok? ur opinion please !!! do they match?
port hxwxd<------- ? help on this one
If you add the end of the box the way you have it, the box will be 39.5" long. Instead, either the make the sides 1.5" shorter or the ends 13.5 x 15.5. Take the internal dimensions:
36.5 x 15.5 x 13.5 / 1728 = 4.42
Sub displacement is .07/sub = .14
4.42 - .14 = 4.28
Make a port in between the sub that is 13.5" tall and 1.5" wide. It will be 13.75" long and this will tune it to 28Hz. Let me know if you need a pic.
2006 Jeep Liberty
Adire Audio, Cadence, Clarion, MB Quart
Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
*Vb = vol. in cu"
**R = sq.rt. A / Pi (for square/slot port)
Bookmarks
