Results 1 to 3 of 3
Reload Thread: Do you see a problem with this box?
    Bill T.'s Avatar
    Bill T. is offline Senior VIP Member
    Jan 2004
    Wyoming
    320
    External Dimensions
    38" Wide
    20.5" Deep
    16" Tall
    Port
    14.5" x 4" x 15"
    3/4" MDF, no bracing.
    I came up with 4.85 cu.ft after displacement and 58 sq" of port area. Tuning is at 33Hz.
    Does that look right?
    Thanks,
    Bill T.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Re: Do you see a problem with this box?
    1.) The dimensions you gave are external so...36.5 x 14.5 x 19 / 1728 = 5.82cu'
    2.) If the port is sharing a side with the box, then it's safe to say that the port displacement is .57cu'? (4.75 x 14.5 x 14.25 / 1728 = .57)?
    3.) You did not post the sub displacement so I'm guessing .4cu'?
    4.) I got a tuning freq. at about 38Hz (would have to be 23" long to get 33Hz.)
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    Bill T.'s Avatar
    Jan 2004
    Wyoming
    320
    When measuring port length, isnt it from the edge outside to the middle of the 90 degree bend, then again from the 90 degree middle point to the end of the inner board?
    I have 2 designs in mind and I keep coming up with 36-38Hz tuning.
    Bill T.
  1. A bigger box?
    By xSomeguyx in forum Enclosure Design & Construction Help
    Last Post: 03-02-2004, 12:52 PM
  2. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  3. tryin to fix oversize box problem
    By tweakd2thepeak in forum Enclosure Design & Construction Help
    Last Post: 12-25-2003, 04:22 PM
  4. box problem..
    By kyleg94cavy in forum Enclosure Design & Construction Help
    Last Post: 12-22-2003, 10:39 PM
  5. basic box questions
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-22-2003, 05:04 AM
