Results 1 to 2 of 2
Reload Thread: 2 12's box dimensions(reg cab)
    pj2003's Avatar
    pj2003 is offline Senior VIP Member
    Dec 2003
    thomasville
    197
    Icon30 2 12's box dimensions(reg cab)
    i have 2 rockford fosgate HE 12" subs. i have a reg cab silverado so i'm tite on space. i want to make a box tha goes all the way across the back wall so i can get alot of displacement in the boxes. the subs top mounting depth is 5 13/16 inches. what does that mean. if u can give me some box dimensions for this type of box give me a link to a site with one. needs to be sealed(duh reg cab) want the box to be as thin as possible(depth) make up for that in width. and i also still want to be able to fold center console up. kinda picky aint i. also tell me a good type of wood to use and some good sealant products and how to cut a good circle
    Mirp's Avatar
    Mirp is offline bumpin high
    Dec 2003
    Ohio
    57
    Re: 2 12's box dimensions(reg cab)
    use 3/4 mdf and gorilla glue or liquid nails (something like that) and caulk if u need.top mounting depth should be depth of speaker overall,sticking in and out of box.should have a paper that says how many cubic ft u need,cant think of it on them subs.i left maybe a 1/4 inch behind my magnets on my mtx's in my 91 silverado. i have 2 boxes both 7 deepat bottom and 5 at top,21 long, and 16 tall (outside diameter) and they are .77 cubic ft.i cut cardboard to what size i wanted (took in account board thickness) and checked to see how skinny i could make em,think u should do the same
  1. 15" sub in box for xtended cab truck
    By bobo244 in forum Enclosure Design & Construction Help
    Last Post: 01-22-2004, 11:59 PM
  2. 1997 Dodge Ram Extended Cab box :/
    By esco in forum Enclosure Design & Construction Help
    Last Post: 01-22-2004, 06:03 PM
  3. box for 2 12's
    By DonJ in forum Enclosure Design & Construction Help
    Last Post: 10-07-2003, 02:34 PM
