Results 1 to 3 of 3
Reload Thread: Alternative to fiberglass?
    ecstaz's Avatar
    ecstaz is offline Junior Member
    Jan 2004
    Denver
    I was just wondering if anyone had ever heared of using molded plastic for a sub enclosure? The reason I ask is because I have a vacuum form machine, and I wanted to construct the baffle part of an enclose using molded plastic. The plastic I would use is about 1/8" thick, so I would glue together several layers. I don't know if you have ever seen a vacuum form machine but what you do is heat a flat sheet of plasic until it is soft, then place it over your mold on the table and turn on the vacuum. The soft plastic instantly takes the shape of the mold, and then hardens as it cools. I know I couldn't make an entie enclosure this way, but using it for one contoured section might be feasable, and easier than fiberglass.
    Any advise on this idea, or better yet experience?
    Thanks!
    taylor's Avatar
    taylor is offline THUNDER TUNES IS A FLAMER
    Jan 2002
    can
    30
    1,509
    2 Post(s)
    Re: Alternative to fiberglass?
    probably to thin still.....to much flex
    Apr 2003
    Los Angeles, Southern Cali
    28
    84
    yeah i would know. i tried to use some thin *** lexan for the top of a box... i got pissed cuz it flexed and rattled soo much that i took the subs out and threw the box against a wall.
    Legally Breaking the law.
    Music of the Moment: Story of the Year
  1. fiberglass fitment
    By chopstick1981 in forum Enclosure Design & Construction Help
    Last Post: 01-16-2004, 09:15 AM
  2. ---READ---Something that would make fiberglass more fun for everyone!!
    By mayday0017 in forum Enclosure Design & Construction Help
    Last Post: 01-12-2004, 07:24 PM
  3. Mark, Ramos, Mike ... Fiberglass Port ?'s.
    By ss3079 in forum Enclosure Design & Construction Help
    Last Post: 08-05-2003, 12:08 PM
  4. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
