Results 1 to 4 of 4
Reload Thread: WINisd help
    runningame21's Avatar
    runningame21 is offline beyond recognition
    Jan 2004
    Albuquerque, NM
    36
    68
    WINisd help
    Ok, I am using WInisd to try and design my first ported box. I am new to building boxes, and had some questions.
    1. Is it better to put two subs in one chamber, or seperate chambers?
    2. The gain graph on WINISD is confusing to me. What should it look like? Should the line go above 0db? If so, how much is ok? I just need to know what the gain slope SHOULD look like.
    3. Does WINISD take into consideration port and speaker displacement?
    Jan 2004
    Albuquerque, NM
    36
    68
    Re: WINisd help
    Oh yeah, Im wanting a hip hop sound. Thats what I listen to mostly. What frequency should I tune to?
    Jan 2004
    Albuquerque, NM
    36
    68
    Re: WINisd help
    Oh yeah, and when calculating box volume, do you add in the space INSIDE the port? Here is a crappy rendition of my design. Subs are RFP1212 Punch DVC's. What is this tuned to? Do you see any issues with this design?
    I-------------------------------------------------I
    I _______ _______ I
    I I I I
    I I I I
    I I I I
    I I I I
    I I I I
    I I I I
    I I I I
    I I________________________ I I
    Box is 15x17x43.5 (exterior, using 3/4 mdf)
    Ports are 13.5x2 26 in long.
    I believe this is right at 5 cubic ft.
    The gain curve shows as follows in WINISD with these measurements.
    -3 db at 29hz
    -1 db at 32hz
    0db at 34.5
    1db at 38hz
    1.7db at 47hz
    1db at 72.
    Should the gain be higher at the 30-40 range? or am
    Jan 2004
    Albuquerque, NM
    36
    68
    Re: WINisd help
    well, that didnt work. Ill post a pic later
  1. Replies: 8
    Last Post: 01-15-2004, 01:03 AM
  2. winisd port calculations
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 01-01-2004, 08:50 PM
  3. New WinISD Pro Kicks ***
    By Bavarian3 in forum General Discussion
    Last Post: 10-03-2003, 11:09 PM
  4. understanding winISD
    By chinxtaboi in forum General Discussion
    Last Post: 07-27-2003, 01:39 AM
  5. winisd? or something
    By LuNaTiC in forum Enclosure Design & Construction Help
    Last Post: 07-25-2003, 11:48 AM
