Results 1 to 2 of 2
Reload Thread: 18" 4th order blow through
    Popwarhomie's Avatar
    Popwarhomie is offline CarAudio.com Elite
    Jan 2010
    Jacksonville, FL
    762
    2 Post(s)
    Single 18" HDC3 for now.. Might be a little longer than I thought to buy the 2nd 18".
    Truck bed is 19" tall, 60" wide, 17" long, then 50" between wheel wells to work with. Im guessing 38hz would be good for the HDC3.
    Im guessing 4th order would be best for me because I don't want to cut a 15"+ hole out of the cab. But I don't have da mad skillz to design a 4th order..
    Help please?
    Thanks
    1994 Ford Lightning
    Pioneer 80prs/AQ1200D/SA-8s/Kicker KS 6.5" comps/400.4/optima red top/200 amp alt/
    2010 Focus
    Pioneer 80PRS/(Walled)2 DC lvl 3 18s/AQ1200D/AQ120.4/AQ 6.5s/ AlphaDamped /KnuKonceptz wiring/102AH Batt
    2kyukon's Avatar
    2kyukon is offline Member
    May 2010
    wi
    65
    Re: 18" 4th order blow through
    this is basically the same thing i want to do except mine is going to be ported through the rear window.
