Results 1 to 5 of 5
Reload Thread: plexiglass...
    rocktonic13's Avatar
    rocktonic13 is offline Member
    Oct 2003
    orlando
    109
    plexiglass...
    what do i use to cut plexiglass? also, what would be good, clear, glue and sealent to use? this si probally going to be for a side window type deal... also, what would i use to cut a miror?
    PopcornPlaya's Avatar
    PopcornPlaya is offline Senior VIP Member
    Jan 2004
    durty south, ga
    35
    172
    Re: plexiglass...
    you can buy precut windows, im assuming you mean windows on your car, from FAL (flex a lite). www.flex-a-lite.com
    "Whattaya lookin' at? You're all a bunch of fvcking assholes. You know why? 'Cause you don't have the guts to be what you wanna be. You need people like me. You need people like me so you can point your fvcking fingers, and say "that's the bad guy." So, what dat make you? Good? You're not good; you just know how to hide. Howda lie. Me, I don't have that problem. Me, I always tell the truth--even when I lie. So say goodnight to the bad guy. Come on; the last time you gonna see a bad guy like this, let me tell ya. Come on, make way for the bad guy. There's a bad guy comin' through; you better get outta his way!"
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: plexiglass...
    They sell bits for different kinds of saws that are specifically for cutting plastics. Dpepnds on the kind of mirror. If it's plastic you can use the same bit. If it's glass, a glass cutter. As for glue or sealant. IF it's going to join two pieces of plexi use plexi glue. It dries crystal clear. If you mean sealing a window to the box. THen you can either run a bead of silicon around the edge of the opening. Allow it to dry comletely before putting the window in. And make a silicon gasket. Or use some rubber weatherstripping around the window edge.
    5 % equipment
    90 % install
    5% beer
    Oct 2003
    orlando
    109
    Re: plexiglass...
    ramos, what do you mean by makeing a silicon gasket? could you possiblely go into more detail...
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: plexiglass...
    Yeha man it's pretty simple. Run a bead of silicon around the opening where your going to put your plexi window. Let the silicon dry completely. That way when you put the window in. You effectivly have a silicon gasket I.E. the dried silicon bead.
    5 % equipment
    90 % install
    5% beer
  1. plexiglass
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-14-2003, 11:36 AM
  2. Plexiglass box panel
    By Q45guy in forum Enclosure Design & Construction Help
    Last Post: 08-18-2003, 01:39 AM
