Results 1 to 3 of 3
Reload Thread: Difference Between Shared Or Seperate Chambr Sealed Box
    Tragedy116's Avatar
    Tragedy116 is offline Junior Member
    Dec 2003
    New Jersey
    32
    17
    I have purchased two 12 inch magnum D2's and have thrown them in a 3.2 cubic foot sealed bo that is a sealed chamber due to space in my trunk. I heard many differences about having subs in either sealed or seperated sealed chambers. What are the main differences? What are the advantages or disadvantages of having a shared chamber sealed box over a seperated chamber sealed box?
    LoneRanger's Avatar
    LoneRanger is offline Old Yamahas Give Me Wood
    Dec 2001
    Wellston, Ohio
    35
    1,379
    Re: Difference Between Shared Or Seperate Chambr Sealed Box
    Quote Originally Posted by Tragedy116
    when two subs share a common sealed chamber and one sub is weaker than the other it creates a push-pull effect that's not healthy for either woofer. if you happen to blow one woofer without blowing the other, it will most likely take the other one with it if it's not taken care of very quickly. I always suggest seperate sealed chambers for subs, and have recently removed the surcharge on my website for seperate sealed chambers to encourage their use.
    PS: The recommended ported enclosure for a magnum is 2 cubic feet per driver....you sure you couldn't squeeze another cube out of the trunk space?
    "There is no 'I' in Tag Team"
    Project 'rex: Coming Soon to An Eardrum Near You
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    I would agree with Lone Ranger. I would recommend at least 2 cubic feet of box volume ( after port and speaker displacement) for any ported boxes per sub. Unless you absolutely cannot get anymore room. I had my two 10" subs with about 1.5 cubes each and they still didn't sound as good as when i had my single 10" sub... but they were louder. That and i was trying to get set up for competition so SQ really didn't matter... as much... still needed some SQ though. Cant be driving around with crappy bump at any time. As for the common and separated chambers.. i usually will do a single chamber but i could tell if something was wrong with one speaker and could shut it down. But if the person playing the music cannot tell when something is wrong then i would reccomend a separated chamber.
  1. Two 12's in shared or seperated sealed chamber?
    By Tragedy116 in forum Subwoofers
    Last Post: 01-15-2004, 10:21 PM
  2. whats a good size sealed box for 12 eD sub
    By frozenfire89 in forum Enclosure Design & Construction Help
    Last Post: 01-11-2004, 07:30 PM
  3. A few quick ?'s about sealed boxes
    By BaTooK in forum Enclosure Design & Construction Help
    Last Post: 12-24-2003, 09:41 AM
  4. sealed box sizing for a single orion xtr 12s?
    By moturbopar in forum Enclosure Design & Construction Help
    Last Post: 12-05-2003, 11:31 PM
  5. Replies: 5
    Last Post: 12-05-2003, 11:51 AM
