Results 1 to 9 of 9
Reload Thread: Aq 18s
    Varinabassing's Avatar
    Varinabassing is offline CarAudio.com Elite
    Jan 2009
    Richmond,Va
    1,223
    21 Post(s)
    Aq 18s
    Ok i have about 3300 rms to play with and am thinking about these to hdc Aq 18s would 7 cubes a piece work and wat should i tune to for a daily setup i was thinking low like 32 htz but i want a decent range of notes so should i go 35-38 htz ?? Thanks
    02 Dodge Ram Sport Quad Cab.... 5.9L
    Excessive Amperage 225 amp Alt
    2/0 weld wire
    RF T2500.1bd
    4 Sa-10s 5.3 cubes tuned to 35htz
    still loooking for front stage
    MONSONwarrior's Avatar
    MONSONwarrior is offline Constantly Rebuilding... MONSONwarrior is a Supporting Member of the forum!
    May 2010
    Baton Rouge, LA
    1,707
    1 Post(s)
    Re: Aq 18s
    Never tune an AQ that low. DD and AQ light high tuning and will still hit good low. Tune 36 at lowest, AQ recommends 40 and I think DD recommends 37.
    2002 Chevrolet Trailblazer LT
    Pioneer AVIC-U310BT | Eclipse SC6500 | MB Quart Q4.80
    (2) Fi BTL N2 12 in 4.5 cubes @ 33hz | Cactus K5 | XS D3100 & D3400 | Knu 0 Gauge | Big 3 | 250a Alt
    Jan 2009
    Richmond,Va
    1,223
    21 Post(s)
    Re: Aq 18s
    wow thanks for the heads up did look at the site yet so would 7 cubes at 40 htz still hit say a 32 htz tone ok ? I am a flex guy but like it loud and know the higher the tune the louder it normally gets
    2/0 weld wire
    RF T2500.1bd
    May 2010
    Baton Rouge, LA
    1,707
    1 Post(s)
    Re: Aq 18s
    Personally I'd go around 38hz but... that's the resonant frequency of my car so that gets loud. I think you should be okay anywhere from 38-40 for what you want.
    May 2010
    Baton Rouge, LA
    1,707
    1 Post(s)
    Re: Aq 18s
    Oh, I also forgot to say 7 is probably too small for two of these, AQ and DD call for very close specs to each other and DD 18's are supposed to have 6 per.
    Jan 2009
    Richmond,Va
    1,223
    21 Post(s)
    Re: Aq 18s
    i meant 7 per sub so 14 total. Its going to be a blow thro in to my single cab 1500
    2/0 weld wire
    RF T2500.1bd
    Jan 2009
    Richmond,Va
    1,223
    21 Post(s)
    Re: Aq 18s
    Well as fast as i made this thread that deal has fallen thru. So i might just bite the bullet and buy to new sundown 18s. Wat kinda tune and box size should i go with. I only have 3300 rms to work with a 1 ohm. Thanks
    2/0 weld wire
    RF T2500.1bd
    *SlappinAzz*'s Avatar
    *SlappinAzz* is offline Shoot em
    Mar 2010
    Virginia
    4,244
    1 Post(s)
    Re: Aq 18s
    Quote Originally Posted by Varinabassing View Post
    Get two xcon 18's, 390$ each.
  9. #9
    May 2007
    Louisville,ky
    4,224
    2 Post(s)
    134 Post(s)
    Re: Aq 18s
    Should be nice. just don't go that low on the tuning. 35hz should be low enough.
    Refs-Skip01, Jmanjr, goodie, DubbDesigns, joem1cha3l, Kawasaki STX-R, audiobahnuser18, djhn9, Jeeper09, cityboy21, sporty_drew, FLOSSINON24S, wong05tsx, thaster, Acizzle423, soloXgt, mobeious, Cloak559, ldyzlvudis06, pickup1
