Results 1 to 7 of 7
Reload Thread: AW1206T Box Help
    NavyCTO's Avatar
    NavyCTO is offline "Classified"
    Jan 2004
    Fort Meade, MD
    32
    22
    AW1206T Box Help
    I currently don't have my vehicle. I joined the Navy in August, and am at my training school now. I graduate next month and decided I want to build my own box. I'm going all out SPL. It is supposed to be tuned to 31.5Hz. I'm gonna make it 32" x 15" x 15". It will have two 4" Ports that are 12" Long. Where should I place the ports. I plan on putting a Plexiglass Front on the box, because I'm taking out the rear seat and cutting out the wall attaching the back seat and I'm gonna recarpet around it and place the box there. Any help or recommendations would be highly appreciated. Thanks for your time.
    Trixter's Avatar
    Trixter is offline Keepin it Simple
    Apr 2002
    Colorado Springs, CO
    40
    2,609
    29
    2 Post(s)
    Re: AW1206T Box Help
    First off, for an all out SPL box, I would tune it higher, like around mid 40's. Also, if your going with round ports, look at getting precision ports from www.partsexpress.com. Try facing the ports on the same side as the sub is.
    2006 Jeep Liberty
    Adire Audio 15" Brahma running off Cadence A7hc, Clarion hu, MB Quart 6.5s and 5.25s running off old school Punch 800a4
    146+db @ 38hz with 1200w and a single 15"
    Lv = [(14630000 x R^2) / (Fb^2 x Vb)] - 1.463R
    *Vb = vol. in cu"
    **R = sq.rt. A / Pi (for square/slot port)
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    Well i just ran a few quick box prospects and here is my conclusion.
    If you want all out SPL, You'll need a bigger box, if you want it to sound anything like a speaker and not a unknown tone of brapppppp brap braaaappppp. The box that you are building is 2.6 some odd cubic feet around 2.45 after speaker displacement. With a box this small you will begin to get distortion a long time before you get close to your speakers RMS.
    You will need to tune the box higher like the trixter said... but you don't have to worry about that because two 4" ports at 12" long is tuned to 42.36 hz. And with that setup you have a 6 db port gain at 40 some odd hz.
    Then there is the problem of port size... when you hit 40hz or so you will begin to hear distortion ( mainly chuffing ) of the ports due to the high air velocities... they reach around 60 m/s.
    I think that's it... if i missed anything else guys let me know.
    NavyCTO's Avatar
    Jan 2004
    Fort Meade, MD
    32
    22
    What is the formula you used to get that Cubic Footage readout. The one I used said that equaled out to slightly over 3.2 ft/3.
    Oct 2002
    Fort Meade, MD
    35
    873
    Yes, but you still have to account for speaker displacement ( .27 cubes) and port displacement ( .2 cubes ). And i was wrong i added in the speaker displacement in wrong. But you still only have about 2.6 cubic feet. But you will still need larger ports to accomodate all of that port velocity which will know it down to about 2.47 cubic feet. All test were run using Leap 5.. and for the volume calculation i just used 7th grade math.
    NavyCTO's Avatar
    Jan 2004
    Fort Meade, MD
    32
    22
    Ok. I only have room to make the box deeper. If you don't mind could you how much deeper the box needs to be to give myself 3.2ft/3 airspace?
    Trixter's Avatar
    Apr 2002
    40
    2,609
    29
    2 Post(s)
    You posted the dimensions but failed to tell which ones were H, W, and D. Here's what you do: multiply H x W x D / 1728 = cu'. Use the inside dimensions. (If you are using 3/4 MDF then subtract a total of 1.5" ( .75+.75=1.5) from the external measurements.) Play with teh numbers until you get the volume you need.
    And really, I have used 2 4" Precision ports for a single 15 and they sounded awsome.(got me a 146.2 on linear-x.) They are designed to cut down the turbulance by their flared ends. Also they won't take up as much displacement as a slot port would.
    2006 Jeep Liberty
    *Vb = vol. in cu"
  1. basic box questions
    By missionpilot in forum Enclosure Design & Construction Help
    Last Post: 12-22-2003, 05:04 AM
  2. better box building...
    By rocktonic13 in forum Enclosure Design & Construction Help
    Last Post: 12-21-2003, 01:12 PM
  3. just made a box
    By bass maniak in forum General Discussion
    Last Post: 11-30-2003, 05:32 AM
  4. help me with a box for JBL GTI 10s
    By slug420 in forum Enclosure Design & Construction Help
    Last Post: 10-28-2003, 10:51 AM
