Results 1 to 12 of 12
Reload Thread: slot port vs aero port (pnr)
    blackdrag450r's Avatar
    blackdrag450r is offline Senior VIP Member
    Apr 2010
    wisconsin
    198
    3 Post(s)
    i'm in the process of having my local builder build me a box for my 12" fi btl.
    I want him to do a slot port but he reccomends pnr ports, which i believe is the same as aeros? he says they are easier to do and that they are less noisy?
    what are some of the pros and cons of both and which way should i go?
    thanks guys
    fasfocus00's Avatar
    fasfocus00 is offline doITdaWHITEwayORdoITtwice
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Re: slot port vs aero port (pnr)
    search, it's only been discussed 10000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000000000000000000000000000000 times
    Here is my feedback Thread: http://www.caraudio.com/forum/showth...ght=fasfocus00
    "If you ain't cheatin', You ain't trying"
    Apr 2010
    wisconsin
    198
    3 Post(s)
    wow, with that many zeros you could have given a logical explination....
    you try using the search on this site... its a pile of ****!
    fasfocus00's Avatar
    Jun 2007
    New Orleans, LA
    5,618
    3 Post(s)
    459 Post(s)
    Quote Originally Posted by blackdrag450r View Post
    google doesn't work on your computer
    aeroportspwn's Avatar
    aeroportspwn is offline mmmm aeroports
    Apr 2010
    FL
    546
    68 Post(s)
    thanks guys
    lol.
    only cons of aero ports if any would be that they cost more since with the slot ports you just use the wood/mdf you already have..
    Pros of aero ports are: Easy to tune, you can cut some of your tubing off and quickly change your tune. If it is a true aero port with flared ends on both sides you need less square inches of port area per cubic foot of your box vs a standard slot port. A true aero port only needs about 6-10 square inches of port area per cubic foot as a slot port needs about 12-16 per cubic foot..
    You can mount aero ports externally if needed very easily..
    you are welcome most of this is easily accessible with the search feature/google also.
    refs on here: bought from PioneerSPL1990, amartin_72, fasfocus00, Kowboy | Sold to evildave101, Louisiana_CRX, KAC1023, Zachfeen, ds0110 | refs on caco: 72impala, super_duper, KAC1023, tandrel | refs on ebay: my username is chevy-guy87
    Tone415's Avatar
    Tone415 is offline A.K.A FrisnoG
    Feb 2009
    San Francisco, CA
    29
    2,007
    i are banned from google...
    Current Set up:[05-03-11] 2000 Chevy Impala
    Sub: 2x 15" SSA Icon d1 in a DCTV box
    Sub Amp: Audiopipe ap18001d
    Fronts: Boston Acoustics Pro 6.5x
    Rear: Rockford Fosgate 3-Way 6x9's
    Speaker Amp: Sound Stream Van Gogh 500.4
    HU: Alpine IXA-w404 - 8gb Ipod nano
    Electrical: 220 DB Electrical Alt - Big 3 in 2/0 g - Yellowtop 34/78 upfront - Deka Intimidator in the rear
    ciaonzo's Avatar
    ciaonzo is online now TheContinental
    Feb 2009
    WI
    42
    10,735
    15 Post(s)
    1030 Post(s)
    Quote Originally Posted by Frisnog View Post
    Ya gotta search more than pr0n once in a while, lol.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
    geonfreaq's Avatar
    geonfreaq is offline CarAudio.com Elite
    Apr 2004
    norfolk, VA
    36
    730
    Figues
    2007 Dodge Ram 2500 Mega Cab
    -Kenwood DNX 6180
    -PowerBass ASA 400.2
    -Hertz 165
    -Memphis PR1X1000
    -2x SA-8D4 - 1.5^3ft @ 32hz
    SOLD TO: Louisiana_CRX
    BOUGHT FROM: dreid, Frisnog, SPL KID, fasfocus00, galacticmonkey
  9. #9
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    30
    6,222
    One isn't necessarily better than the other, each has its better applications.
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
  10. #10
    Apr 2010
    wisconsin
    198
    3 Post(s)
    like?
  11. #11
    Ali1's Avatar
    Ali1 is offline e6300 FTW
    May 2006
    U.S.
    3,508
    slot ports offer bracing, whereas aeros provide little to no support to the structural integrity of the enclosure. aeros are expensive and need to buy seperately as opposed to using the same sheet of mdf/trupan/birch for your build with slots
    Quote Originally Posted by northside210 View Post
    seems like everybody is going for pyle, should i tune them to 63 for the lows or 87
    refrences:
    logan_searching, Big Rea$e, rfluvinmf, Davecubs14, reaudiofan, Krazed4Bass, SR20det, jbizzle x 4, bamaboy, mazdakid, mike11202,sbcaprice305, anotherguy(yes, that is his sn), ROE, coreyanderson, gebrochen, 528hz, bassmasta (x2), ustroops52, noob24,vrwm, lafanboy, explodftl,TheLow, tommythecat,dub22, hunterw, many more.....
    **** PATALPINE :: SCAMMER******
  12. #12
    Apr 2010
    wisconsin
    198
    3 Post(s)
    what about sound? where spl is no concern and the box is tuned to 32-34 hz in a daily system?
    just looking for what will sound the best but still have the best output.
  1. aero port or slot port
    By nate56 in forum Enclosure Design & Construction Help
    Last Post: 03-01-2010, 09:50 PM
  2. Which is better Aero port or slot port?
    By crfrider in forum Enclosure Design & Construction Help
    Last Post: 05-09-2009, 03:39 PM
  3. Aero Port Vs Slot Port
    By muskyhunter567 in forum Enclosure Design & Construction Help
    Last Post: 10-27-2008, 12:38 AM
  4. Slot port vs. aero port?
    By T9X in forum Subwoofers
    Last Post: 06-09-2007, 11:05 PM
  5. aero port or stick with slot port...?
    By paulie in forum Enclosure Design & Construction Help
    Last Post: 06-14-2006, 06:36 PM
