Results 1 to 6 of 6
Reload Thread: Fiberglass Dash parts
    DannyD's Avatar
    DannyD is offline Junior Member
    Jan 2004
    Ma
    30
    17
    Do I have to do anything different in order to fiberglass onto plastic such as a trim bezel? I am fluch mounting a DVD screen into the dash of my 97 Mustang and will use the trim bezel as part of the frame.
    I have never fiberglassed before but, after reading many writtings, threads, pictorials, discussions...ect on how to do it ,I believe i have a pretty good idea.
    If anyone has any advice on my particular install i would greatly appreciate it.
    (P.S. here is a link to a page that shows how I would like to install the screen http://www.caraudiomag.com/v_feature...ang/index.html )
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,302
    5 Post(s)
    Re: Fiberglass Dash parts
    You will need to scuff the plastic pretty well with some 40 grit sandpaper. Then clean the plastic well. And get to glassing.
    5 % equipment
    90 % install
    5% beer
    DannyD's Avatar
    Jan 2004
    Ma
    30
    17
    Do i smooth it out or leave it scuffed to adheir better to the cloth, glass,and resin ?
    Dec 2003
    Austin, TX
    29
    86
    leave it scuffed
    fiberglassing is not as easy as it looks. if i were u i would start on something small not my dash!
    cause if u **** up it aint coming out and every1 is going 2 see it.
    try fiberglassing a box etc. then when u get a feel for fiberglassing move 2 ur car
    when its done it should look tight! good luck!
    -capone
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    whats the stock part look like? I dont think youd have ot use fiverglass for that.. could just bondo it
    DannyD's Avatar
    Jan 2004
    Ma
    30
    17
    Ill get some pics for you guys in the morn......
  1. check out my fiberglass box *PIC*
    By subboxmaker in forum Enclosure Design & Construction Help
    Last Post: 01-31-2004, 02:14 AM
  2. speaker placement in the dash?
    By moturbopar in forum Speakers
    Last Post: 01-07-2004, 07:11 PM
  3. How thick should my fiberglass enclosure be?
    By jlaudiow6 in forum Enclosure Design & Construction Help
    Last Post: 10-12-2003, 11:07 AM
  4. the sound of fiberglass
    By iammiowngod in forum Enclosure Design & Construction Help
    Last Post: 07-24-2003, 05:03 PM
