Results 1 to 4 of 4
Reload Thread: subwoofer direction
    chawski's Avatar
    chawski is offline Senior VIP Member
    Oct 2009
    Philadelphia
    150
    4 Post(s)
    subwoofer direction
    Ive seen a few builds on here that has the cone of the subwoofer facing into the box, which really got me wondering why you would do this. Are there any benefits to this or is it just the cosmetics the builder chose? Other than with a bandpass, ive always had my speakers facing outward. does this work in a sealed application or only vented?
    x2o's Avatar
    x2o
    x2o is offline Fuzzy Blue Lights
    Nov 2007
    Miami/PSL, FL
    3,714
    Re: subwoofer direction
    Well, part of it might be cosmetic, but mounting the subs inverted will also help save on displacement, in a multiple sub setup this might help you achieve a smaller box. Mounting it standard with the motor in the box causes a bit of displacement, on some SPL motors it is around .2 cubic feet of displacement, so you can see how with multiple subs the little .2's can add up. I'm sure there are a few other reasons too, but thats the main one i've considered.
    The System :
    Electrical: Big 3, Powermaster D1200 and D3100.
    Sub Stage : 18" Custom Sundown Nightshade D2 Tuned to 30 Hz
    Sub Amp : Sundown SAZ-3000D
    Headunit : Alpine 9887 (ACTIVE )
    Front Stage : (2) Eminence Delta 10" mids, 2 Power Acoustik NX-5s
    Rear Pro Audio: (4) 8" Selenium 8W4P, (2) Selenium ST350
    Pro Audio Amps: Hifonics ZXi6010, Hifonics ZXi1010, Kicker ZX350.4
    Wiring : Kicker Hyperflex/Knu 0ga/RCA's
    Refs : Apocalypse Boy, Brian Owens, JBLCamry, ABSOLUTEAUDIO, BushJ311, tEh koRnDog(x2), blackbonnie, ProjectPat06, ampjunkielikeme, DownSouth954, Tapout, PaulThompson229, Mrogowski, Team H&K (Kent), andrewmoore13, slam, 100% eBay
    chawski's Avatar
    Oct 2009
    Philadelphia
    150
    4 Post(s)
    yea that makes sense. do they sound the same tho? better, worse, indifferent?
    ContourSPL's Avatar
    ContourSPL is offline Senior VIP Member
    Jun 2006
    Paoli, IN
    327
    You won't notice a difference
