Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: 2.0^[email protected] help?
    richie92ex's Avatar
    richie92ex is offline Member
    Jan 2009
    Ocala,FL
    50
    Im trying to build a box for a RE *** 12 d2. If any of you box savy guys can hep me with a design that would be awesome. I'd like it to be per RE specs (2.0^[email protected] 33 unless anyone thinks I should do something different. I have 30" of width and 15" of height to work with. the depth can change. I would like to make the box with as much port surface area as possible as I have come to understand that that reduces port noise, and aids in better SQ. Thanks in advance for any help.
    Ride: 92' Honda accord ex
    Deck: Eclipse cd3200
    Amp: MB Quart 4125
    Front Stage: Image Dynamics ctx65 comps
    Sub: RE audio se/x 12 in [email protected] via areoport
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,499
    14 Post(s)
    2172 Post(s)
    richie92ex's Avatar
    Jan 2009
    Ocala,FL
    50
    Re: 2.0^[email protected] help?
    I hear that thing is not very accurate?
    Amp: MB Quart 4125
    ascitiesburn69's Avatar
    ascitiesburn69 is offline CarAudio.com Elite
    Jul 2008
    New Orleans, LA
    558
    More port area does not aid in SQ, in fact it may worsen it dramatically. I would try to do around 24-30sqin of port area for a 2cuft net box. But really I would do an aero because it would be a little easier to tune to 33hz than with a slot port bc a slot would have to be fairly long.
    HU: Alpine 9887
    Subs: 4x SA10s
    Amp:Audioque 3500.1 at .5
    Jul 2008
    New Orleans, LA
    558
    With a single 4" aero, you could do 15H, 30W, and 12D. Make the aero 12" long total. This is including sub and port displacement.
    HU: Alpine 9887
    Subs: 4x SA10s
    Fuknmovin's Avatar
    Fuknmovin is offline CarAudio.com Elite
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    Dude, I would not do that box. That is no where near enough port area to make the most from that sub, you will be disappointed. That is only 12 sqin of port area and you should have somewhere around 37 for that enclosure. If you are trying to get loud at all I would put at least two 4"ers in there and that truely is a bit on the small side, everyone thinks you can have half the port area for Aeros, but I have done both many times and you need around 3/4 minimum Aero port VS Slot and you are still a bit short with two. If you plan on doing this, do yourself a favor and use two, it will sound MUCH better, more port area = more sound, almost always...to a point. and as for the SQ thing, if that is what you are going for you should use a sealed box, ported offers virtually no SQ as it creates peaks in the sound where the box is tuned to, they are not linear, that's why we use them so they get louder where we want it!
    A 10 that thinks it's a 15!
    I build and design boxes! PM me for details..
    bballstarx124x Quote: Got it running today. Sounds amazing! I'm getting a lil windshield flex on only 500 watts!
    Refs: MTX9515, [email protected], MSW Danny, 95Prober
    http://www.caraudio.com/forum/showthread.php?t=395576"]http://www.caraudio.com/forum/showthread.php?t=395576
    http://www.caraudio.com/forum/showthread.php?t=394806"]http://www.caraudio.com/forum/showthread.php?t=394806
    Fuknmovin's Avatar
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    Oh and you need the ports 20-24" long you just might have to turn them inside the box using bends you can get at Hoe Depot...
    Jul 2008
    New Orleans, LA
    558
    Wow.....really?? First of all, just because a box is ported doesn't mean that it has a peaky response and where the hell are you getting 37sqin of port for a 2cuft net box? Yes if you are going for all out SPL then do a huge port, however this will definitely lead to a huge peak in your frequency response which from the OP it doesn't seem that he wants.
    HU: Alpine 9887
    Subs: 4x SA10s
  9. #9
    richie92ex's Avatar
    Jan 2009
    Ocala,FL
    50
    I just want a tasteful sounding ported box. I dont need it to be an all out spl machine- I mean hell were talking (1) 12", but I want it to have decent SQ while having a little boom - this way it will sound good and show my boy with 3 xplode 12's that they ****- nothing against sony guys. Another question- While RE says "optimal is 2.0^3 @ 33, I might ask optimal for what? Whats there philosophy on tuning? boom or smooth? I guess I just need some lessons on how to use winISD.
    Amp: MB Quart 4125
  10. #10
    Jul 2008
    New Orleans, LA
    558
    Sx's are daily beater subs so the box is modeled for just that. It will have a slight peak beginning around 30 and dropping off around 50ish. Don't use two 4" aeros otherwise the peak will be higher about 5hz above the tuning freq but it will begin to rolloff much sooner than just one.
    HU: Alpine 9887
    Subs: 4x SA10s
  11. #11
    Fuknmovin's Avatar
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    Quote Originally Posted by ascitiesburn69 View Post
    Its a known fact that the DD port area calc works and works well, and I did not know the displacement so I used the net volume of the box you described or 2.33CF to get close. I understand you might loose a bit of accuracy but to the average listener, you won't even know its gone, because it will hit like you never knew it could. Now if you are doing SQ comps then I would certainly use a sealed box. And I understand that you can get a ported box to be "peaky" in a low enough range that you will not by the ear really notice it by tuning it really low, but I also know that if you don't care about that then you will likely not notice it with a larger port area either.
  12. #12
    Fuknmovin's Avatar
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    Plus he plainly said he want higher output? To each his own, I am just trying to help the guy out. I have and continue to build MANY boxes, Probably more than one a month so I guess you can take that for whatever its worth. I am not trying to prove anyone wrong, just trying to give the guy what it seemed he wanted..
  13. #13
    richie92ex's Avatar
    Jan 2009
    Ocala,FL
    50
    Oh boy, dont sweat this crap guys, Im just a noob. But as far as what i want- like i said, loud with taste, accurate enough for me to listen to whatever, but loud enough to impress- thats it. Now if i cant have a little SPL & SQL like a 50/50 split of both worlds I guess I should have bought a better sub. But for now, its the RE ***. I thought it would be an ok beginner sub, hell it was cheap. Then again, Im new to all of this.....that's were seasoned car audio folks like avid members here come in to steer me right. Thanks for all of the imput so far, I just dont want a BS system, I want it to be somewhat nice for what Im working with. And another thing, I probly wont know it its just a little peaky-just a little, I just want to hear the low stuff too. It would be cool to set it up to wow people playing oh, idk jezzy hypnotize while acting right listening to say steely dan if that makes sense.
    Amp: MB Quart 4125
  14. #14
    Fuknmovin's Avatar
    Nov 2008
    Palm Desert, CA
    591
    7 Post(s)
    No worries, I hope I didn't offend him or you, I just know how it is, you build one then you are thinking...Man I wish it was a bit louder!
  15. #15
    spltuscon's Avatar
    spltuscon is offline Kick-*** box builder
    Jun 2009
    NH
    818
    Check your PM's
    Dave The Box Guy
    154.4 db USACi Stock 601-1800- NH S.R. 2009
    152.4 db legal in WCP1 TNESPL 2010
    150.9 db legal in Stock 1 NESPL 2010
    150.5 Street C Db Drag 2010
    2010 Woofer Cooker Pro 1 champ
    2009 NESPL Competitor of the Year
