Whats the opinion on the subs facing away from each other like this?
AFAIK (but don't take my word for it), they would cancel each other out. You'd have to have two of their phase's reversed I think. I'm probably wrong, so wait for someone with more experience to post![]()
Feedback: http://www.caraudio.com/forums/buyer...ck-thread.html
The Ride: 1991 Spirit
The Sub: AudioQue SDC2.5 15" (4.2cf @ 38hz)
The Sub Amp: Audiopipe AP1500.1D
The Front Stage: Pioneer TS-C1353 Components
The Front Stage Amp: Pioneer GM-3300T
why not just get subs that would fit on one wall?
Bought from:99grandprixGT,chereck04,Shinju, mrmakinmoves,basscort2009,TnT_Sounds, Sicaudio,KHARPS
trades with:Bologna,Jordon32990,kraudio12
SOLD TO: j225, taylorfade, dkhage1 , vulocity22
2009 Subaru legacy se
headunit: JVC-KR8500
Front fill: 2 ST350 and 8 6" selenium
Substage: 4 sa10's in a 4th order
Sub power: Sundown 3500 at .5
Electrical: Yt under hood 6 33ah in the trunk, 1/0 shok everywere
What about upfiring the subs with the port on one of the sides?
Ive heard the reversed polarity thing. Any other oppinions? no room to upfire, its in a trunk
I've done subs facing either side of a trunk before. Should work fine as is, why not port forward? would give you a lot more room.
that makes me happy to hear, and I might port forward, im gonna try both see what sounds better.
IA 40.1, Nakamichi PA350, Arc audio 6.5s 2 way active (1986 Alphasonik x-over) Audio Control three.1, Kenwood KDC-X592, TREO SSX based 18: 8 layer flat wound copper coil w/ dual SS former, 3 medium nomex spiders built by SPLaudio and repaired by myself and Harshaw for optimal sexiness and performance.
team Dbeez MECA as3 db3
☞2218☜ βθπ βν
gay idea, you are better off with a couple of 15s or 18s, im guessing they are 10s or 12s you want to do, need more info
refs
woc47, nigro013, defconx3, louisiana_crx, bld 25, supa_c, lancer1978, sxkicker89, 310w6, more, i forget
how is that "gay" in any way? they are 12"s, I'm using all the space in my trunk as efficient as I possibly can. figure out a way to use 36x33x15 any better with four 12"s (LxWxH) and you let me know. they require 2 cubes each.
why cant you fire up?
www.BassHeadsENT.net for all your custom enclosure needs
Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
Robin@BassHeadsENT.net
Check this thread for all the build logs being posted.
http://www.caraudio.com/forums/suppo...ks-thread.html
Bookmarks
