heya,
So I'm working on building my first box... It's for a single jl10w0. JL recommends 0.75cubic at 125rms. I'll be feeding it 150rms, so as I understand it, I can make the box a bit smaller (say around 0.7)? Now, does it matter how I design the outter dimensions as long as the internal volume is the same? ie: Will a 0.75 box be the same regardless of how the outer dimensions are built?
What's the best way to seal the edges of the box? I was planning to use wood glue and screws to hold it in place and then maybe some silicon caulk along the inside seams. Will that work ok?
Also, is there any way I can mount the box in my car wihtout having to drill through anything? any sort of velcro setup or something?
Thx
Register To Reply
Bookmarks
