Results 1 to 2 of 2
Reload Thread: 4 12" subs, box suggestions.
    stickytak's Avatar
    stickytak is offline Junior Member
    Apr 2010
    Michigan
    28
    I'm putting 4 12"s in my trunk, and I have an area of 36x36x16 high, that I can construct in and be able to fit it in and out of my trunk. they call for 2 cubes each with a ported box, first of all, does that 2 cubes include the port area? And Im curious what you guys think I should do.
    My plan originally was the basic all four subs facing up with a 36x36x14 box ports on the ground, two forward, two back. but, that only leaves a few inches up for sound to get anywhere.
    So then I decided I would put two subs forward, two back, the ports on the ground facing the way the subs are... but I'm just not really sure what to do....
    Overall:
    Does the ported recommended cubes include the port.
    and
    What do you guys think the best box design would be in a 36x36x16 space, walls at roughly 37 width, 39 depth, and 17 height.
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    31
    21,086
    2 Post(s)
    457 Post(s)
    Re: 4 12" subs, box suggestions.
    2ft^3 is after all displacements.
    2,500+ designs since March 2011
