Results 1 to 6 of 6
Reload Thread: Anyone Have A S-10 Ext cab?
    joshm78's Avatar
    joshm78 is offline Junior Member
    Dec 2003
    Bowling Green, KY
    25
    Im trying to get Ideas of A single 12" sub setup in a 99' S-10 Ext cab w/ third door. I built a box out of 3/4 Oak plywood. Not sure of the size but when I really crank it up it acks like it's starving for air. It sound really great at low to about 30% volume. It's a sealed box and I have it downfiring and the only place I could tell it could be leaking was around the sub where it joins the wood.
    I have a Infinity Kappa Perfect 12DVQ dual 4 ohm VC and I have a JBL 600.1 amp
    Do I need to completly scrap the box that I have and build another. If so, I want some Ideas on shape and size.
    I am BIG on SOUND QUALITY !!!!!I am willing to give up some loudness for the Quality. I have a new 4' x 8' sheet of 3/4" MDF in the shop just waiting on whether I should use it.
    ps> I AM NOT FAVORING MDF OVER PLYWOOD OR PLYWOOD OVER MDF !!!!!
    Plywood was what I had around to use the first time and since I had to buy some new I chose what was cheaper!!
    Thanks
    josh
    yamaha326's Avatar
    yamaha326 is offline livin loud
    Dec 2003
    Texas
    938
    Re: Anyone Have A S-10 Ext cab?
    well downifire is good but u prob need to look at your box better or it might even be the sub
    phoneman's Avatar
    phoneman is offline i like pie
    Feb 2002
    ok
    33
    3,697
    S-10 ex cabs are hard to get loud. I have one and I was dissapointed with my first system I put in it so I put it in my sisters hatch and it totally wanged in it. They are just a tough vehicle to get loud
    TPABlazer's Avatar
    TPABlazer is offline Senior VIP Member
    Oct 2003
    Fort Myers, FL
    31
    368
    I know theres a thread on s10forums.com but i think you have to be registered
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    plywood is pourus/*****=bad SQ< !MDF!
    It's worth the $$$$$$ for MDF!
    HEZEKIAH's Avatar
    HEZEKIAH is offline Junior Member
    Feb 2004
    Missouri
    I made a enclosure for my x-cab, it held four ten inch Xtant subs. Sounded awesome. Then I created a single chamber box that held eight ten inch JBL's didnt sound as great.
  1. single cab truck - no room, help me
    By rambassmachine in forum Subwoofers
    Last Post: 12-01-2003, 08:47 PM
  2. Need help with 2000 Chevy ext. cab
    By HarleyF150 in forum Subwoofers
    Last Post: 11-20-2003, 05:14 PM
  3. box for 1 12" magnum d2 in a 97 dodge ram ext cab
    By esco in forum General Discussion
    Last Post: 10-01-2003, 01:31 PM
