Results 1 to 8 of 8
Reload Thread: Gluing Port to Box
    undeadxsunshine's Avatar
    undeadxsunshine is offline what it is
    Nov 2008
    York, PA
    1,246
    Gluing Port to Box
    I used pvc cement to glue my pieces of port together. What type of glue should I use to attach the port to the mdf box? The pvc cement again or wood glue or something else?
    2001 Mazda Tribute
    HU: Alpine CDA-9886
    Front Stage: Hertz HSK 165
    Front Stage Amp: Crescendo 1000C4
    Sub: 2 Diamond D3 12"s in 4 ft^3 @ 34hz
    Sub Amp: Sundown SAE 1200d
    Refs: ampjunkielikeme, clbolt, SPL-Master, Twisted_0912, Qbenjamin, plyer3, tr10av, Lucid15, Alter Ego Trip, Topless Stang, Gville, wgsj_fortvalley, PioneerSPL1990, l4yfr4me
    Feedback Thread: http://www.caraudio.com/forum/showthread.php?p=5791608#post5791608
    marcotheclepto's Avatar
    marcotheclepto is offline CarAudio.com Veteran
    Feb 2009
    United States
    2,465
    Re: Gluing Port to Box
    what kinda port...? (material) if mdf use titebond II wood glue good stuff.
    need a box design? click here or email Dragonsk8er14_2@yahoo.com
    1997 Buick LeSabre Limited
    wiring:2 runs (2 pos 2 neg) of 0 ga big 3 in 0 ga 50 ft of knu cca, and 36 ft of the wire loudcartunez sells...
    Head unit: Kenwood excelon KDC-X692
    Sub Amp: Autotek Mean Machine 4000D
    Subs: 2 custom 15s built by ssackett
    Sub box: 4th order bandpass 2.52 cubes sealed 5 cubes ported tuned to 59 Hz
    comp amp: CDT SQA4100
    Comps: 2 sets of CDT CL-61i
    Deadening: 50 cld tiles and 20 sq ft of damp pro.
    feedback please post if you have had any transactions.
    http://www.caraudio.com/forum/showth...19#post6113819
    Plottin4success's Avatar
    Plottin4success is offline CarAudio.com Elite
    Oct 2008
    In a kitchen, Louisiana
    25
    1,384
    Its an aero. I would just use screws and some silicone around the inside if it to seal it up.
    Nov 2008
    York, PA
    1,246
    port is plastic made by precision port
    2001 Mazda Tribute
    HU: Alpine CDA-9886
    Nov 2008
    York, PA
    1,246
    eh didn't really wanna use screws, i think it'll look a lot cleaner without them.
    2001 Mazda Tribute
    HU: Alpine CDA-9886
    phemps's Avatar
    phemps is offline CarAudio.com Elite
    May 2009
    PA
    1,262
    I dont know i stick to slot port but im thinking your not going to be able to get the hold you want being the port is plastic and box mdf. i think your gonna have to go with the screws and silicone as mentioned
    Refs: Rio, DbzArson, goodstuff, Worstenemy453
    Quote Originally Posted by Altec View Post
    Then obviously I am asking the wrong person, because you don't know how to hook up subs if they sounded like "****". Maybe learn your ohms and your diagrams before you call something ****. Learn to make boxes to specs and use the right wires and its called dynomat. Then maybe your car wouldn't of sounded like ****, yeah?
    Jan 2005
    Farmington, NM
    2,324
    19 Post(s)
    If you use silicone, the port will be removable for use in another box at a later date. Titebond II might not let it go without damage.
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Or use some skinny weatherstripping from Home Depot...that's what I use for my subs that don't have a rubber gasket.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
