Results 1 to 5 of 5
Reload Thread: Box size and tuning for a low end monster
    hatedonmostly's Avatar
    hatedonmostly is offline throwin' hunnits, hunnits
    Jun 2009
    Detroit, MI
    26
    6,382
    17 Post(s)
    I currently have one AQ SDC2.510 in 1.5 ft^3 @ 40 and on 900W. My new setup is going to be four RE RE 12's on 1200W.
    For the new setup, I want it to be a low end monster. This is going to be in the bed of a single cab Dodge Dakota. I want to be able to do hairtricks, which I don't think should be a problem considering how small the cab of the truck is and how much cone area I'll have.
    For the subs, RE recommends 1.25-1.5 ft^3 @ 35. Is 35 really low enough for hairtricks, because I see a lot of people tuning lower for them.
    I was thinking 30-33 Hz, but also don't want to lose my high end (40-50). But would I have to worry about that? Considering four 12's is six times the cone area of one 10", wouldn't it still be louder at 40 Hz, even if the box was tuned as low as 30?
    And for box size, I have no clue. I see a lot of people with groundpounders have bigger boxes. 4x1.5=6.0 ft^3, or should I make it bigger?
    All opinions would be appreciated...
    psych0ticnemes1's Avatar
    psych0ticnemes1 is offline Psych0tic Customs
    Apr 2005
    Behind You
    5,842
    175 Post(s)
    Re: Box size and tuning for a low end monster
    I think a tuning of 32 hertz would work well for you. I don't think it is possible to lose output at any frequency when going from a single 10" to 4 12"s.
    References:
    Ali1, michaellane, cadillac114, chasinSKURT, DaRevrin, rhuff80, sam yung, The215, tukn18s, Xenophontos,nuboot,jfitz97,LuckyDerDer 2x
    Jun 2009
    Detroit, MI
    26
    6,382
    17 Post(s)
    Quote Originally Posted by psych0ticnemes1 View Post
    Thanks man, it's good to see you're reinforcing what I'm thinking. Anyone else?
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I agree with the lows 30's tuning. If you make the box bigger it will decrease your mechanical power handling. I had an Fi Q on 500w in a 5.5 cube box. It hounded on the lows. One problem with the bigger box is that the higher notes sounded like ***.
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    outsideshot23's Avatar
    outsideshot23 is offline CarAudio.com Veteran
    Nov 2009
    OKC
    3,528
    8 Post(s)
    I have mine tuned to 38 and do hair tricks.. plays music well and still competes. i have ext cab 08 sierra... 35 sounds right...
    First hair trick... more to come -----> http://www.youtube.com/watch?v=tbfADio5CjQ
    [email protected] usaci
    155.5 @44hz Usaci Streatbeat
    [email protected] MECA
    [email protected] MECA Driveby
    Team XS power
    Team SecondSkin
